Old 07-20-2011, 07:56 PM   #1
1973 Argosy 24
Pearland , Texas
Noob with an Argosy
Hi ya'll! I just bought a 73 Argosy about a month and a half ago thinking I would buy something cheap that works. I'd been dying for a travel trailer and and couldn't stomach paying too much for just a plain old run of the mill white box). After a month of work its almost campable and ready to start playing while I continue to fix it up. I've already ordered new axles (its way too low for my comfort) and after that the basket on the back is gonna have to go! Then of course paint, bodywork and flooring as money permits. I've been reading the forums since I got it and figured I should join instead of just being an "info stalker" Anyway thanks to you all for all the tips so far and I'll share all that I figure out along the way!
Fujak
ID:	135507   Click image for larger version
Fujak is offline   Reply With Quote
Old 07-20-2011, 08:06 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Well, Welcome! Glad you are enjoying your Argosy. This is the place to find out what you need to know for sure!
Lance
Top is offline   Reply With Quote
Old 07-21-2011, 09:47 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Noob with an Argosy
Greetings Fujak!
Welcome to the Forums and the world of Vintage Argosy ownership!
I am certain that your Argosy will provide many miles of memorable travels!
One suggestion . . . . . you might want to add a rock guard to your restoration plans. The front panorama windows are quite expensive to replace and the clear deep-wrap-wing-windows are no longer available (the new wing windows are only available with solar tinting). Even if the thought of a new replacement wing window with solar tint doesn't bother you, the price might -- one replacement wing window can cost in the vicinity of $750. A three-piece rock guard for the modern "narrow-body" Airstreams will fit your standard Argosy coach (the center section must be modified for Minuet models).
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 07-21-2011, 10:01 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Welcome from another Texas Argosy newbie! I just got mine in April.
David
DKB_SATX is online now   Reply With Quote
Old 07-21-2011, 10:23 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us. That's a nice looking Argosy. We'd love to see some pictures of the interior.
SuEllyn & Brian McCabe
Old 07-21-2011, 10:28 AM   #6
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Very nice! We have a '73 Argosy26 that we are in the midst of fixing up.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 07-21-2011, 07:54 PM   #7
1973 Argosy 24
Pearland , Texas
Thanks All! And thanks for the rock guard suggestion, Overlander. I cringe at the thought of having to pay so much for new glass that wouldn't even match the other side.... Oh yeah and here are a few pics of the inside. The top two are right after I got it so you can see I've got lotsa work to do.....
ID:	135559   Click image for larger version
Old 07-21-2011, 08:27 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
New axles, new paint, cleaned up inside . . . that'll be a nice trailer. Thanks for posting.
Old 07-21-2011, 08:39 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
So was the fresh-water tank under the dinette and you removed it? Is something wrong with it, or you're just restructuring that part of the interior?
David
Old 07-22-2011, 02:41 PM   #10
1973 Argosy 24
Pearland , Texas
I removed the freshwater tank, cleaned it out and replaced all the hoses to it and to the water pump. I did'nt like the dinette cause it was so small so I bought a futon and attached to a custom sliding frame I built over the top of the water tank. Replaced the raised table support in the floor with a countersunk one so it didn't stick up. I'm not a big stickler for keeping it all original so I thought I would go with the better use of space. Still need to replace the flooring and add the oak and beech cabinet doors before it looks good but at least its functional now.
Old 07-22-2011, 03:48 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
Well, sounds like you're way behind on posting updated interior pictures then.
My dinette is different, it's not a wraparound. Unfortunately, the water tank is in the same place, so for 4 ppl to sit at the dinette, the forward 2 have to have 1 leg each on top of the water tank. Oh, and there's a nice sharp metal edge on the box that covers the water tank, I discovered that the first time I slid way in to open the front window.
David
Old 07-22-2011, 05:34 PM   #12
1979 Argosy Minuet 7.3 Metre
Hill country , Texas
Awesome Argosy!
We are new Argosy owners as well. Upgraded from a casita so we REALLY appreciate the extra space! Looks like you've got a great find! Are you planning to do your axles yourself? We are in for axles as well, and I'm contemplating it, so just wondering what your experience was. Welcome and that's a great looking Argosy!
ArgosyGypsy is offline   Reply With Quote
Old 07-22-2011, 09:47 PM   #13
1973 Argosy 24
Pearland , Texas
Gypsy, I am going to do the axles myself, Right now I'm praying that they come in next week so I can put them on and go play since I have the first week of August off.... If not looks like I'll put it back together (I've taken one of them off already) until they do. I am going camping one way or another! As far as replacement goes, I found the info in this thread by TOP most helpful. http://www.airforums.com/forums/f437...ead-74177.html He goes all the way though the quotes he got, why he went with Colin Hyde (one of the nicest, most helpful guys ever I've ever dealt with) for his axles and loads of photos and info on how he installed them. As many have said there are plenty of DIY types who have installed their own axles with no issues. I would read Tops' thread and the many others on here before proceeding and that will give you a good idea of what's involved. IMHO not a whole lot to it and if you run into trouble there are plenty of folks here that will have the right kind of advice to help to get you out of a jam.
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 21 06-08-2014 10:46 AM
Argosy maiden voyage. shortcake All Argosy Trailers 18 09-29-2011 10:33 AM
1974 Argosy Sphere Guy Trailer Values 11 07-05-2011 12:04 PM
Argosy shakedown cruise to Tyler State Park DKB_SATX Our Community 18 06-27-2011 09:06 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
