Old 12-17-2010, 10:19 PM   #1
1970 27' Overlander
Hernando , Mississippi
Question Newby with tailight assembly falling out of "ARNI" 1970 overlander
On our tow home, the roadside taillight assembly came loose held on by wires. The rivets wasted away or corroded loose. Any suggestions how to reinstall? The housing was pop riveted on from back side. The 40 year old cast tail light assembly appears in fine shape but i would have to remove all interior to redo pop rivets. Cast assembly might be stretched by rivet. Any ideas?
Coastie is offline   Reply With Quote
Old 12-18-2010, 12:06 AM   #2
x
XXXX , XXXX
The service manual says to reinstall the taillight housing from ouside by drilling through ouside of the housing into the shell and use pop rivets. It says to drill through the housing in the groove just inside the outer edge of the housing. Clean out all the old rivets from both the housing and the shell. Install pop rivets in the old rivet holes in the shell to seal the holes and use a putty tpae around the outer perimeter of the housing before reinstalling.
wasagachris is offline   Reply With Quote
Old 12-18-2010, 11:46 AM   #3
1970 27' Overlander
Thanks for the info.
Do you know where i can get a service manual?
Old 12-18-2010, 12:08 PM   #4
The first service manual came out for the 1972 models, which for all intents is the same as a 1970 model.
" 1970 airstream travel trailer 24' nice " eBay Watch Airstreams on eBay 0 03-14-2010 05:00 PM
Airstream 27" Overlander 1970 Brakes Luc_DK Brakes & Brake Controllers 16 07-06-2009 03:10 AM
1970 Overlander "Airstream Called Desire" Derin_Don Member Introductions 4 02-07-2007 07:51 AM
General hello and "help wanted" by newby Jbgrh61 Member Introductions 2 10-07-2006 10:56 AM
