Old 06-01-2008, 05:14 PM   #1
1966 22' Safari
Seven Valleys , Pennsylvania
Newbie with a 48 Liner project
Hi all, I'm new to Airstreams, over from Scottys. Found a 1948 Liner project that I will pull with my 1941 Ford panel truck. Looking forward to lots of help here on the board. Thanks! Larry in PA
scarylarry is offline   Reply With Quote
Old 06-01-2008, 05:20 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Airforums, ScaryLarry... Sounds like an interesting project. You'll find everything Airstream here...poke around in the subforms for specific information...or ask away...somebody will have the answer...or at the minimum, and opinion!
Glas you could join in...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-01-2008, 06:06 PM   #3
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
Welcome to the forums. When you get a chance post some photos (just click on the paperclip while you are making a post). Where is PA are you? Good luck with your project - there is plenty of information available just start asking questions. Was this the liner fro sale in Grand Junction, CO?
April & Andy Hershberger
www.ClassicAluminumTrailers.com
3streams is offline   Reply With Quote
Old 06-01-2008, 06:13 PM   #4
1966 22' Safari
Thanks for the welcome. The unit was local. It's no peach, but it is mine!!
A shower/toilet will be added to the rear. Still trying to figure what we can do for a sofa bed/portable table combo. The photo was our Christmas card this past year.
Name:	100_6120 (Small).jpg
Old 06-01-2008, 06:17 PM   #5
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Great looking combo!! Love it...I would think a stainless table would be a must in that trailer...
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 06-01-2008, 07:04 PM   #6
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Is the Liner a pipe frame? I am curious as my '50 Flying cloud is and I would be interested in your plans in modernizing the trailer. Adding water holding capacity, both fresh and not so fresh, I felt the pipe frame to be inadequate. I beefed up the frame with added steel. Now I am concerned I will also now need a beefier axle. You will probably pass me up in your restoration, so please hurry so I can learn from your mistakes. Just kidding. I have made enough that I have little learning capacity left. Good luck. Keep the pictures coming.
Gene
FC7039 is offline   Reply With Quote
Old 06-01-2008, 07:20 PM   #7
1966 22' Safari
Gene, I will post photos as I progress. I do plan to move this project along quickly this summer. I have a buddy that has redone several Airstreams (later units) but we put a plan together this past week. For the waste tanks I plan on two 20 gallon tanks and a square tubing "step up" based on top of the center round frame That will hopfully make the round tube more stable and give my tanks a solid foundation to support them a little higher from the ground. I've built some hot rod frames and hope some of that will carry over!
Old 06-01-2008, 08:09 PM   #8
1966 22' Safari
3streams, we are just south of York PA.
Is this a 1947 Liner? cosmotini 1947-1949 Liner 9 12-28-2011 03:57 AM
'47 Liner lwebb Trailer Values 16 11-07-2010 05:34 AM
Newbie with a '48 Liner scarylarry Member Introductions 4 02-06-2008 11:10 AM
1948 Liner Jim Carmichael 1947-1949 Liner 14 07-03-2006 06:18 PM
Is this a Liner? AYRSTRM2 Vintage Kin 4 09-07-2005 08:24 PM
