Old 08-02-2007, 02:31 PM   #21
Asheville , North Carolina
OK people,
Thanks for the response. So maybe a 22 footer. Question: Is the Tacoma V6 too small?
levi2 is offline   Reply With Quote
Old 08-02-2007, 02:57 PM   #22
plossl's Avatar
1974 25' Tradewind
Greenwood , South Carolina
I think you're towing capacity is 5,000. You could pull a 22, but you'd be working your truck. It's not too small, but the lighter the better. You could probably pull a 26 footer over the mountains if you stayed in 2nd gear, but it would be a long trip. Is your truck an automatic?
plossl is offline   Reply With Quote
Old 08-02-2007, 05:00 PM   #23
1960 22' Safari
in the wilderness , The great Mojave Desert
There is a wieght difference between the Safari Sport and the the other models. The SPort being lighter. Just more facts to knock around your brain while you do your research.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 08-02-2007, 07:55 PM   #24
plossl's Avatar
1974 25' Tradewind
Levi2-
Note this recent post in " Please stop me if I am headed in the wrong direction" on the main portal page--
You must be looking at an older Tacoma to be rated at only 3500 lbs...we tow our 2006 19' Bambi with a 2007 Tacoma...rated at 6500 lbs with the factory tow package...but anythng bigger and, "Houston, we'd have a problem." Toyota has beefed up their trucks recently...thank goodness...as a Tundra won't fit in our garage! The Tacoma is performing quite nicely and that's even up and down some steep grades...we aren't going to win any races in those situations, of course, but we can keep up to the speed limit, which is the most any of us should be doing, anyway!
Good luck...and many Happy Trails...TB
Newbie vallan1980 1965 - 1969 Overlander 27 07-11-2009 03:53 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Newbie Needs Info... TheJarvis Our Community 13 11-06-2002 09:31 AM
Newbie looking to restore old AS Paul Brown Our Community 1 10-05-2002 05:04 AM
Airstream Newbie jaiman Airstream Motorhome Forums 10 09-08-2002 07:47 PM
