Old 10-24-2015, 08:53 AM   #1
1965 17' Caravel
Hull , Massachusetts
Newbie in Massachusetts Black water tank
Hi,
I am an owner of a 1965 Caravelle and will be looking to the community for guidance and expertise on fixing up my AS. I have been reading the postings in the forum for a year now and I am at a position where I can somewhat intelligently explain my repair needs and get advice on how to proceed. The generosity of the members to share their knowledge is reassuring to me and I hope I don't become a pest.
There is floor rot along the rear channel in the wet area. Which I will remove and replace. My first question has to do with the black water tank. I drilled out the rivets to the rear belly wrap and dropped it. The wrap looks as if had been removed before. I expected to see the black water tank but only found the waste line running from the sink and shower drain. Pictures included. My question is, is the black water tank above the floor but below the molded raised area where the toilet (picture enclosed)located or was it removed?
Since, I believe will have to pull the overhead storage, refrigerator, sink, stove, heater, hot water heater and wardrobe to remove the one piece bath area I will be back seeking your knowledge.
Thanks in advance
Ron
repairsart is offline   Reply With Quote
Old 10-24-2015, 03:06 PM   #2
Gainesville , Florida
Probably above the floor as on some new models.
Old 10-24-2015, 05:09 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the toilet is sitting on a riser above the floor level that is the tank.
2004 Excursion 4x4
Old 10-24-2015, 05:14 PM   #4
65CV's Avatar
Western , Massachusetts
There's no picture attached, but that is where the tank goes. Yes, there is quite a bit of removal needed to get the one-piece bath out.
If I remember correctly, C Johnson had a new tank made that was larger than the original, taking up some space in the base of the adjacent closet. I took a quick look and didn't find it in his thread.
In case you are unaware, there is a sub-forum devoted to '65 Caravels. It's here. There is a gold mine of information there. Happy hunting.
65CV is offline   Reply With Quote
Advice on Storage options for Massachusetts Flying Cloud Newbie bluef150 Winterizing, Storage, Carports & Covers 1 08-18-2015 01:28 PM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
