Old 04-27-2010, 01:17 AM   #1
River17's Avatar
2004 25' Safari
Las Vegas , Nevada
Exclamation Newbie from Las Vegas
Just getting my feet wet with my first post here.
I hope to be able to do some more looking around this forum in the days ahead while I research how big an Airstream trailer I can tow behind a Mercedes Sprinter. They say the towing capacity is 5,000 lbs., so I need to get ideas or suggestions from other members that may also own a Sprinter.
Not sure if I can get away with a tandem trailer or if I'm relegated to just being happy with a single axle trailer.
River17 is offline   Reply With Quote
Old 04-27-2010, 06:35 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
With a tow vehicle that is rated for 5,000#, that pretty much puts you in 22' and smaller Airstream territory if you are considering a late model unit. Vintage Airstreams are not as heavy, and you could handle a larger Airstream.
Brian
SuEllyn & Brian McCabe
Old 04-27-2010, 07:04 AM   #3
Road Ruler's Avatar
Images: 38
Some info here.... http://www.airforums.com/forums/f160...eam-45199.html
Old 04-27-2010, 07:47 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Welcome. Nothing wrong with a single axle TT. A number of us in the 4Corners unit have them and haven't any problems.
Ahab is offline   Reply With Quote
Old 04-27-2010, 10:23 AM   #5
River17's Avatar
2004 25' Safari
Las Vegas , Nevada
Thanks for the feedback and suggestions so far.
Old 04-27-2010, 07:12 PM   #6
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
Welcome to the forum River17! You will find everything you need to know and a lot you didn't think you wanted to know right here on this forum..Glad you found us. I don't think you'll be sorry...
76sovereign is offline   Reply With Quote
Old 04-28-2010, 10:49 PM   #7
River17's Avatar
2004 25' Safari
Las Vegas , Nevada
Ahab
I will explain why if given the choice I would go for a tandem axle trailer over just a single axle trailer.
My one and only experience RVing was back in 1989, when I drove both of my parents on a 39 day 9600 miles trip to Alaska via Inuvik and Fairbanks.
I drove my father's short wheelbase Ford window van pulling a 1976 16 foot Shasta single axle trailer that my father had bought to use as an office at his job sites building spec houses in the San Francisco Bay Area.
Before leaving on this trip I went and bought 4 new 8 ply radial tires for the van and never had any problems. But for the RV they said that I should just stick with new bias ply tires and not to get 8 ply steel belted radial tires. Sure enough, by the time we got to Inuvik we had to buy 2 new Micheling 8 ply steel belted tires after getting two flat tires with the arrow sharp rocks in the gravel roads.
Also the single axle trailer had all of its weight, some 3500 lbs I think just spread over two tires. Even though I aired down the tires on the washboard gravel roads, it seemed like many of the pipes and fixed appliances shook themselves loose and had to be replaced. Also by the time we finally got to Anchorage we had to replace both leaf springs due to metal fatigue.
From that trip I quickly realized that it is better to have the weight of your RV trailer spread out over 4 or even 6 tires instead of just two.
Now over 20 years later I am starting again from square one trying to settle on an RV that will get me to those far away places in one piece and economically.
Las Vegas skipj On The Road... 17 04-21-2013 08:34 AM
Las Vegas KOA Safari-Rick Off Topic Forum 3 02-08-2009 09:33 PM
West las vegas boondocking? timot54 Boondocking 10 10-14-2007 02:06 PM
Hi from Las Vegas LVD&D Member Introductions 12 10-11-2007 03:31 PM
Greetings from Las Vegas jpgordon Member Introductions 13 09-18-2007 10:06 AM
