Old 04-12-2009, 03:14 PM   #1
1973 25' Tradewind
edmonton , Alberta
newbie advice
Hello to all and happy easter,
I'm new to this forum and excited to be part of the airstream community. I have wanted an airstream since i was young after seeing them flow down the highway. I'm now in the position to get one. They are however rather scarce here in Alberta, now I think I found a likely one. Its a '69 Overlander thats been to serveral continents. it looks rather good on the inside, which i will renovate later in the year. My main concern is the exterior. the bottom front skirt? seems rather dented up and needs replacing. there doesn't seem to be any major dents anywhere else, just a few small dings. I should cut to the chase: what should I be looking at on the exterior to judge its condition? how about underneath? I look forward to all advice.
Thank You in advance,
Snakeman:
snakeman is offline   Reply With Quote
Old 04-12-2009, 03:25 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
If you could post some pictures, we might be able to be more helpful.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-12-2009, 03:47 PM   #3
1973 25' Tradewind
edmonton , Alberta
Thanks Brian, will do
Snakeman
Old 04-12-2009, 04:16 PM   #4
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Snakeman,
Nobody would want you to run from a vintage unit but you need to do a lot of research on this forum as to what to look out for. You probably should be most concerned about what you can't see as opposed to what you can see.
Unless the belly pan is removed you really can't see the most impostant part of an AS, which is the frame. On older units this is usually there weak spot. Look for weak spots in the floor by see if any of the floor flexes under your feet. This will be most likely just as you go through the door and under the bathroom floor.
Take and ice pick crawl under the cabinet stick it into the floor around the perimeter of the trailer see if it's solid. Slide out the beds check along the floor there too. check the floor directly under the air conditioning unit and ceiling vents, they can leak and soak the carpet and the leaks can go undected for years.
Go look at the trailer armed with knowledge and then came back and ask more questions. Your Airstream is out there waiting for you somewhere.
POST PICTURES
Annette
bullydogsmom is offline   Reply With Quote
Old 04-12-2009, 04:45 PM   #5
1973 25' Tradewind
edmonton , Alberta
1969 overlander
here are some pics i received showing the outside.
snakeman
ID:	78305   Click image for larger version
Old 04-15-2009, 08:37 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Where's Andy??
Looks like it will need the axle's replaced.
Outside looks pretty darn nice.....
Welcome Aboard
Good Luck & Sweet Streams
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 04-15-2009, 10:19 PM   #7
1973 25' Tradewind
edmonton , Alberta
69 airstream
hi all,
well since i posted the pics of the '69, i found another AS. A '74 24' LY. its mint original on the inside and well cared for. However, the outside has been painted silver and black on the belly pan. not sure what this was all about. Thinking I my be able to strip paint off or go really modified and paint in a cool colour scheme. Do many people ever paint AS? I hope no one throws eggs at me for even thinking it LOL.
Any advice on stripping the silver paint?
Snakeman
Old 04-16-2009, 04:34 PM   #8
Hey Snake....two Streams already? You are going full speed ahead!!!
RLC
RLC
"Tahawus"
Old 04-16-2009, 04:42 PM   #9
1973 25' Tradewind
edmonton , Alberta
hey Robert, shouldn't be full stream ahead?LOL
Snakeman
Old 04-16-2009, 05:14 PM   #10
Snakeman
Which ever Airstream or Argosy trailer you may decide to buy, checking out the axles, could save you a lot of money.
You can check them out in 30 seconds by reading the following article.
The Dura-Torque Axle
Old 04-16-2009, 05:47 PM   #11
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
There are a couple of painted Argosy trailers on this Forum. I know the Argosy comes painted; however, these have had the color changed and they are just beautiful. One is cream and black. It belongs to smokelessjoe, the other is I believe Blue Thunder. Try to find them if you can. Some Airstreams were painted silver to keep from having to polish or replace the clear coat. I believe Inland Andy wrote about it once and how well it can work out. PM him and see.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 04-16-2009, 08:50 PM   #12
1973 25' Tradewind
edmonton , Alberta
thanks for the link Andy, I will print it out. Hey Judy and Bob, I sort of a 50's retro kind of guy. I am in love with the parade of progress GM buses that once toured. Seeing as the 74 AS has been over painted, might be able to talk it down in price. I would like to paint it the red and ivory found on the above tour buses. I will be coming home with it this weekend, hopefully.
Thanks to all for making this a very welcoming forum.
Snakeman
Newbie needs advice/help nmbryant Member Introductions 3 07-08-2006 10:25 AM
Advice for a newbie catalystx2 General Repair Forum 5 08-03-2005 09:57 PM
newbie needs advice chipw Our Community 25 10-09-2004 05:10 AM
Newbie needs your advice mopar7 2004 Safari 25 01-17-2004 08:04 PM
Newbie needs your advice Vanessa Insurance & Claims 2 12-01-2003 08:26 PM
