Old 10-30-2011, 09:50 AM   #1
1962 24' Tradewind
thomasville , Georgia
Newbie
Well hello
I just bought what I thought was a 71 trade wind landyacht. Turns pout none of the floorplans match my trailer. Serial 242d973.
I would like to get to the bottom of the mystery.m Bought the nuvite sampler and cyclo to begin the polishing. It appears that there is something on the surface that we need to get through. It is going to be fun but well worth the work. I am not lookin gto do a complete restore but would like to have something to be proud of . Any infoor conversation will be greatly appreciated.
siddellr is offline   Reply With Quote
Old 10-30-2011, 09:56 AM   #2
Originally Posted by siddellr View Post
Well hello
That serial number is a 1962 24 foot Airstream.
Old 10-30-2011, 11:12 AM   #3
1978 Argosy 27
Lacey , Washington
Images: 8
Welcome to the AS forums and to the world of AS products. We own a '78 Argosy/AS 27ft which re rehabed last year. jjustce
jjustice is offline   Reply With Quote
Old 10-31-2011, 05:23 AM   #4
1962 24' Tradewind
Thank you for the info on the year model. I need a GOOD suggestion for a stripper to use before I start the pollishing process. What is the original sealant used on my trailer. I bought the Nuvite sampler set to get started, now I see people using the colored bars. What is the best product to use for polishing.
Old 10-31-2011, 12:36 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Newbie
Greetings Siddellr!
Welcome to the Forums and the world of Vintage Airstream ownership!
Your 1962 coach may not have any coating on its skin as PlastiCoat was an option in 1962 that wasn't applied to all coaches. Even if this optional coating was applied to your coach, the likelihood is that it has disappeared from all but the most protected areas. One of the tests for the existence of Plasticoat was to utilized a light color rag and rub toothpaste into the surface . . . it the rag turns black, there is no PlastiCoat present. If Plasticoat is present, there are a number of threads on the Forums about stripping the coating . . . most suggesting either Citris-Strippers or Aircraft Strippers. My suggestion would be to be cautious about utilizing strippers if your coach doesn't have an extensive presence of Plasticoat as the harsher chemical strippers also remove products utilized to seal seams and openings.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Newbie in NJ deanNdonna Member Introductions 16 09-27-2011 04:39 PM
NEWBIE asking for your help IN PURCHASING A 'ONLINE' TRAILER Lady Bird Our Community 0 09-20-2011 07:59 PM
Newbie Basics Question(s) Stonew98 Member Introductions 10 02-27-2011 08:21 PM
