Old 12-10-2013, 11:38 AM   #1
1978 28' Ambassador
Seattle , Washington
New "To Us" 1978 Ambassador Seattle, WA
Hi everyone....we were lucky to find this airsteam in good condition which is now are home....I am looking to update where I can while preserving the classic style. I would like to start with floors and other areas that I might not think of and am hopeful I can find good suggestions here. Certainly if any come to mind right away please mention in quick reply to help facilitate my Reno!!.....Thanks
mdsarge is offline   Reply With Quote
Old 12-10-2013, 11:44 AM   #2
Two things to do to start.
1. Make super sure that the trailer is weather proof. Check all the gaskets, especially the sewer vent pipe cover gaskets, that only last 2 to 3 years.
2. Next big project, that if you find necessary, will encourage you to save some money for the expense of a couple of axles. Check them out. If original, most likely the rubber rods are history. But, if the trailer will noy go on the road, then bad axles is OK.
Old 12-10-2013, 11:49 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Welcome to the Forums. Before you dive into flooring, check the sub floor (plywood) itself. All, if not virtually all Airstream's of your vintage have some degree of structural floor rot. Use a sharp screwdriver or ice pick & poke the edges of the floor all of the way around, just inside the wall area. You're likely to find "issues" at the rear, below hatches & doors. This is critical to the longevity of your trailer. This must be addressed before spending time & $ on flooring (floor covering). There are numerous threads here & we've talked about it on thevap (the Vintage Airstream Podcast) many times over the years.
Good luck with your project.
Colin
Colin H is offline   Reply With Quote
Steps on 1978 ARGOSY MH Octane Mechanics Corner - Engines, Transmission & More... 4 01-04-2012 04:31 PM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1978 Minuet 6.0 Metre: What's it Worth? BelgianCat29 Trailer Values 4 08-01-2011 09:43 PM
Painting over 1978 Argosy wallpaper? whitefawn Upholstery, Blinds, Walls & Interior Finishes 3 07-21-2011 09:38 PM
