Old 07-29-2007, 12:22 PM   #1
1989 29' Excella
Gulfport , Mississippi
new to rv'ing
We purchased this nice looking 89 excella about 5 weeks ago but have not been able to take it due to a bent stabilizer foot which I replaced. (carefull the holes in the new part didn't match the old, had to drill new holes). More importantly is the Coleman A/C draining into the inside pan, which fills, then the water drops on the floor. The normal drain runs between the walls of the trailer and exits at the bottom. Access to the top of the drain does not seem possible without removing the upper A/C unit. Blowing compressed air (up to 40psi) from the bottom of the drain yielded only a very temporary result, the draining reverting again to the inside. Can anybody come up with a solution ? Pierre pe.pica@hotmail.com or call 228 323 5817 The idea of RVing is also an altenative to boating which has taken a nasty hit with hurricane Katrina here on the Mississippi Gulf coast. We are still without proper harbor/marina facilities and even the Coast Guard station in Gulfport MS is still operating out of temporary trailers. I am also an active coxswain with the USCGAUX FL35.Pierre Willems
Willems is offline   Reply With Quote
Old 07-29-2007, 01:14 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You need to clean the drip tray. or keep blowing it out until the crud all drains down. I would use 20 psi or less. the drain tube is not designed to handle any pressure.
Michelle TAC MT-0
Sarah, Snowball
Old 07-29-2007, 01:27 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I’ve had similar problems this month myself. Get up on top and make sure the tray is clean, or it will just re-plug the drain. Good luck.
Vaughan
Old 07-29-2007, 03:36 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Helllo Neighbor
Pierre,
Buy far, I am no expert with the AC issue but we are close and if I can lend a hand send me a private message and we can take a look. Just left click on my screen name on this post and select Private Message and let me know if I can be of assistance.
Happy Airstreaming and welcome to the Airstream Forums.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 07-29-2007, 06:14 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the forums. We're glad to have you with us.
SuEllyn & Brian McCabe
Old 07-29-2007, 07:07 PM   #6
richinny's Avatar
2011 34' Classic
can a thinner but firm plastic tube be snaked up the drain line? hey, it worked for my heart ;-)
Old 07-29-2007, 08:04 PM   #7
SLVRSRFR's Avatar
Orange city , Florida
Send a message via AIM to SLVRSRFR
Welcome to the forums Willems
SLVRSRFR is offline   Reply With Quote
Guns, Pistols, RV'ing and ?? Felony oxblood On The Road... 56 08-01-2007 02:01 PM
Whose parents got them started RVing? overlander63 Off Topic Forum 19 04-16-2007 01:51 PM
New to RV'ing and would appreciate some advice porterut Member Introductions 5 01-28-2007 07:54 AM
new to RVing and Airstream macandannie Member Introductions 8 05-25-2006 06:28 PM
Nostalgia, Or How You Began RVing overlander64 Off Topic Forum 5 01-24-2003 11:43 AM
