Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 03-18-2007, 12:14 PM   #1
Badco8
Profile:  1976 31' Sovereign
Charlotte , North Carolina
Post New to Airstream - inverter problems already
:ang ry:Well guys, I just purchased an older 31' 1976 Sovereign Airstream along with the problems that go with 31 year old models. I think the seller knew about the electrical problem as i incurred it the first time I staged it at a private club campground. It will stay here year round. it's a get-away on the water 12 miles from home.
First the battery seems to have 6 dead cells. Of course the Univolt is not charging it even when unplugged from a 120 volt 30 amp campground connection. I removed the battery b4 checking for any charging voltage from the Univolt unit just in case the battery had an internal short. I had 110 AC volts upon plugging in the service and the Univolt killed the 12 volt as I have read that this was to be expected.
The previous owner had mounted 110 volt flourescent lights over the kitchen and bathroom sink and over the gaucho couch ( because he liked to have more light, BS ).
Upon plugging in a small ceramic heater for some heat while I read the book and began to perform routine check-ups on the Fridge,furnace,waterheater,etc. my lady asked if I would plug in another real small heater in the front for more heat and I did. While reading the owners manual, I LOST ALL POWER. I FIRST CHECKED THE WEATHERPROOF PLUG-IN AT THE CAMPER REAR AND HAD 110-120 VOLTS. I then proceeded to check the Univolt in the bathroom closet. No Hum. I cannot locate a breaker for the 110 volt to the Univolt and assume the switching is internal and the 110 Volt breaker at the campground pole is the only switch or breaker for the 110 volt supply to the trailer.
If there is some other breaker, please advise as to location. I am 100% sure that being all DC fuses in the supply side of the Univolt are good then the charger function is bad and therefore being an older unit, to heck with doing anything but replacing it.
Even though I am ( temporarily ) parking it, I would like to have the charging option,12 volt dc, and 120 volt feed from a reasonably priced unit. I have no problem with installing a seperate circuit panel after the 12 volt feed but I am also open to suggestions that would be a time saving installation upgrade. I also plan on maybe installing a monitoring panel or even trying to make the one in the front operationall.
I would appreciate any and all help with this problem. I worked for the power company years ago and can solve the 120 problem but I only care to go in the closet,remove the Univolt and MOVE ON.
Badco8 is offline   Reply With Quote
Old 03-18-2007, 12:31 PM   #2
wannastream
Profile:  Currently Looking...
N.E. , Texas
I'm sorry to hear about your disappointing experience with your "new" unit. But welcome to the forums, there are plenty of helpful folks here with lots of good advice and experience to share.
"Like a roller in the ocean, life is motion, move on...
Like a wind that's always blowin' life is flowin' move on...
Like the sunrise in the mornin' life is dawnin' move on...
How I treasure every minute, being part of, being in it, with the urge to move on"
wannastream is offline   Reply With Quote
Old 03-18-2007, 12:47 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
It sounds like you tripped one of the 110 volt breakers with the load of the heaters. They do draw a fair amount of current. The breaker pannel for my 75 Tradewind is located in a closet in the bathroom. It should not be too far from where the 110 volt line enters the trailer. I would replace the battery and the converter. Checkout BestConverter - Inteli-Power Converters, Inverters, Solar Chargers which is owned by Randy (68 Overlander).
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 03-18-2007, 01:21 PM   #4
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Depending of if yours is center bath or rear bath...in the rear bath of that vintage the 110v power panel is in the back of the cabinet just forward of the toilet on the roadside it is a standard appearing gray panel box. IIRC it has 3-4 breakers in it depending on the options and the wiring.
Aaron
WBCCI #2449 AIR #2495
Old 03-18-2007, 01:55 PM   #5
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Buy yourself a cheap 110 volt plug in tester. $5.00 That will tell you if the output from the pole is still ok. Plug it inside to tell if the internal breaker has popped. Locate the panel and cycle both breakers. Your unit did not come with an inverter. Inverters turn 12 volts DC into 110 Volts AC. Converters (your unit came with one called a univolt) convert 110 VAC into 12VDC to run the 12 volt stuff inside your unit and charge the battery. It is a big humming box behind the couch. The 12 volt fuse panel is also located there under a plastic cover. Buy a multimeter to check for continuity and voltages to make sure all of the fuses are ok. Buy a set of replacement fuses, so you have some spares. Buy a service manual for $50 frequently on Ebay. Learn a little about your unit and electricity. It is fun.
Old 03-18-2007, 02:13 PM   #6
Darol Ingalls
Darol Ingalls's Avatar
Profile:
Dwightdi is correct about the two electrical systems in your trailer. I believe your Univolt converter would be located in the bathroom closet (assuming you have a rear bath model) instead of behind the front couch as in newer models. Your 120V breaker box should be there, too. Previous owners do tend to modify their trailers in questionable ways sometimes, but it is all repairable and next time you look for a trailer, you'll be less likely to trust the seller on all points. Darol
Darol Ingalls is offline   Reply With Quote
Old 03-24-2007, 02:57 PM   #7
Waynon
Waynon's Avatar
Profile:  1986 34' Excella
Welcome!
Welcome to the Forum! You're sure not the first to get frustrated, but before long you'll know you AS better than anyone else.
(Probably won't be the last time you get frustrated with it, thought. smile)
Waynon
Waynon is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 19 02-06-2007 02:04 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 02:39 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 09:02 AM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
