Old 02-02-2014, 05:16 PM   #1
SJW
Trenton , Ontario
Smile New to Airstream Community
Hello Everyone
I am new to the Airstream community and would really appreciate some advice. I am looking to purchase a 1969 31 foot Sovereign Twin Airstream trailer.
It is in good condition but I'm told needs new tires and a once over on the plumbing. A/C works and there is a new fridge to instal that is included.
Could anyone give me some advice as to what to look for and what I may need to do to this trailer. I know this is hard to say without seeing it. All items are original. Only two owners. Trailer was passed down to the daughter of the original owner. The original owners bought it new in 1969 and were extremely picky with the trailer.
Any advise regarding Air streams are appreciated . I have always wanted to own one since I saw them going down the road. I plan on going through the plumbing and electrical. Also would replace all four tires.
Thanks for your help and time.
Looking forward to being a New Airstream Owner.
Thank you all for answering.......
nipper is offline   Reply With Quote
Old 02-02-2014, 07:04 PM   #2
webspinner's Avatar
Menlo Park , California
It could be a gem or it could be hiding some inevitable results of aging. Trailers that old will generally need new tires and axles in order to be safe and smooth on the road. These age even with impeccable maintenance.
There is a trailer inspection checklist to follow when looking at a trailer (I'll see if I can find the link). Also, look on the panel on the right for the notification about AirForums volunteer Airstream inspectors. Maybe there is someone nearby with experience who could help you look the trailer over.
A few rules of thumb: Don't assume anything works unless you see it function. This goes for the new fridge too. Also, does the new fridge fit exactly, or will you have to modify cabinets? Are there any soft spots in the floor. Leaks can develop over time, even if the interior is kept spanking clean. Water damage to the subfloor show up as soft spots. Poke around the edges of the floor with an ice pick or small awl.
I'm sure others will have more to add.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 02-02-2014, 07:05 PM   #3
webspinner's Avatar
I found the trailer inspection checklist:
http://www.airforums.com/forums/f138/trailer-inspection-checklist-43294.html
Barbie
Old 02-02-2014, 10:47 PM   #4
Roblin , MB.
Welcome to the forums from Manitoba,
You may have found a gem.
You have been given the link to the inspection sheets / guide so make use of them and as has been suggested attempt to find an inspector in your area. His /her knowledge will be invaluable in helping you reach a decision in whether to purchase or not.
Was this coach kept under cover by the PO's since 1969? If it was that would certainly be a positive thing.
Once you have determined what all may have to be done to this coach and the costs associated to complete the repairs, etc, you have to reach a decision if you are willing and able to add that amount of money over and above the purchase price?
Always remember - this is not the only coach for sale and if you end up having to pass on it something else will show up down the road.
Good luck and complete all the home work
nairnchyz is offline   Reply With Quote
Old 02-03-2014, 04:24 AM   #5
Systems
Originally Posted by nipper View Post
Hello Everyone
The following article will help you check out the running gear.
The Dura-Torque Axle
Old 02-03-2014, 06:16 AM   #6
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Hello Everyone
Hi Nipper,
Welcome to the Forums & congrats on your recent acquisition As others have said, things are likely lurking beneath the surface, so check very carefully. The most critical thing to start with is to determine the starting point for your project, which for most, is floor structural floor rot, rust & axles. You will find a wealth of info here & on The Vintage Airstream Podcast | Vintage Trailer Restoration .
Good luck with your project,
Colin
Colin H is offline   Reply With Quote
Old 02-04-2014, 04:22 PM   #7
SJW
Trenton , Ontario
Hello Everyone
Thank you to all that have posted and provided me with this valuable information I really appreciate it.
SJW
Old 02-04-2014, 06:49 PM   #8
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
You never know...
Hi!
We found a vintage AS Sovereign that was literally garage kept... perfect! just $10,000 more than we had. If I knew what I know now I would have floated a loan it would have been cheaper! But we also saw many AS that were just not worth what they were asking. Don't be in too much of a rush if you can help it. Learn a little here with friends. I have saved serious money over the years and learned lots (even before I had an AS) by lurking here. Our trailer replaces a Sailboat and it is a very happy transition!
captmatt is offline   Reply With Quote
1963 Airstream Safari 22 - Arizona 1920jr Airstream Classifieds 0 01-30-2014 12:01 PM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
