Old 10-19-2006, 06:07 AM   #15
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Looks nice, what is the outlet plug on the bottom right with the little U shaped wire?
'77 Sovereign Intl 31' CB
Old 10-19-2006, 08:15 AM   #16
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
First, apologies for linking directly to the larger pics -- my first pictures posted! I've only just now figured out the thumbnails *sigh*.
The little u-loop allows you to hook up a cable box/modem or satellite receiver before it splits to both monitor outlets (there's another on setup toward the "foot" of the bed, no mount, just cable jack). If you have your own device to plug in, just unhook the loop and one jack becomes input, the other output (on to the monitors).
Hope that makes sense.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-19-2006, 11:04 AM   #17
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Yep, works for me, thanks
Old 10-19-2006, 03:06 PM   #18
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by flyfisher
We had the factory install a bracket on the ousitde wall for us, just above our credenza. So, we can watch the TV from either our dinette or couch. They used an Omni cantilever wall mount that they've apparently customized with an additional aluminum backplate to make it more rigid when mounted on the wall, plus they added velcro straps to hold the mount and TV against the wall when travelling. They also made a wooden box that went aagainst the wall of our trailer where we wanted the TV to be mounted, and the Omni mount is attached to this box. The box itself is tapered so that the TV is actually mounted vertically, considering that the wall is slightly rounded, plus the box is hollow so we can run the wires behind it, keeping them out of view.
As I recall, Airstream charged us something under $300.00 for this, and we bought our own Sharp flat screen TV. Altogether, this was much cheaper than ordering the TV and wall mount as a factory installed option.
John
If you go this route, just remember that the velcro straps probably won't fit around your TV if you have speakers on the sides or if you go with a larger TV than the one that Airstream sells...we had to buy the parts ala carte and the straps were a waste of money.
Family of Disney Fanatics
WBCCI# 4821
Owner's manual Cheryl 1978 Excella 11 08-04-2012 09:35 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
