Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 04-11-2008, 11:15 PM   #15
2airishuman's Avatar
Profile:
Originally Posted by Denbear
... Guess I'll likely be buying a Tundra.
good decision and choice!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-11-2008, 11:59 PM   #16
Denbear's Avatar
Profile:  1975 27' Overlander
Eugene , Oregon
Sincere thanks, on last and prior comments. Happy to already regard you as a friend who's opinion's well worth having. Just fell onto Planet AS Monday, bought a '75 on ebay. Heading out soon from CA to collect her at Charlotte,NC; then cruise 'er down to New Orleans.
cheers
2air'
Denbear is offline   Reply With Quote
Old 04-12-2008, 12:15 AM   #17
Chatham , Ontario
If you weren't nearly 3,000 miles away from Can Am RV, I'd suggest having them build a custom receiver. The image of the Audi unit makes me think they would have no trouble replicating the attachment points and augmenting the design to make it capable of handling a weight-distributing hitch.
I'd expect towing a good handling trailer like an Airstream with a good handling car like an Audi to be a rare treat. I wouldn't expect pulling power or cooling capacity to be issues. The gearing and torque are quite suitable, and these cars are designed to be run at wide open throttle or close to it. Using constant turbo boost may cause problems, but perhaps using a pyrometer to keep an eye on exhaust gas temperature would work as well for a turbocharged gasoline engine as it does for a turbocharged diesel.
AlbertF is offline   Reply With Quote
Old 04-14-2008, 11:55 AM   #18
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
Yes AlbertF, this pretty much sums up the way many others feel too.
Like owning the highly praised Airstream some unique TV's do cost more and do require a certain amount of special prep, extra cost, and considerations.
With professional advice and setup many folks have reaped the benefits of superior handling, fuel economy, safety, ride, and comforts with unique vehicles when towing, and or solo.
Old 04-14-2008, 08:41 PM   #19
Denbear's Avatar
Eugene , Oregon
Ok, I'm sadly resolved to parting w/ the Audi & replacing w/ a 5.7L Tundra. What are your thoughts on towing w/ 4x2 vs 4x4? All new Tundra's are equipped w/ traction control, vehicle stability control & auto ltd-slip-diff. Whatcha think?
Old 04-14-2008, 09:05 PM   #20
Profile:
'bear...
here is an old/recent, lengthy thread on this topic...
4x4 versus 4x2 Tow Vehicle
cheers
2air'
Old 04-15-2008, 01:55 AM   #21
Denbear's Avatar
Eugene , Oregon
Thanks again, 2air', for pointing me in good direction. Got enough input to confirm my instincts. Diff betw 4x2 & 4x4 Tundra is 300 lbs, only 1 mpg each (city/hwy) and $3K. I'll buy it. I won't always need 4x4, but I'll be most appreciative when I do. Which WILL happen.
Next question 2 toss out : Tundra's have stout tow ability built in, but Toyota does offer an optional Reese Wt Distrb hitch. I'm aware of these via this forum, but w/o understanding. This TV has tow capabilty TWICE the weight of my AS. Should the standard stuff suffice, or is Reese the next part of my learning process?
Old 04-15-2008, 03:16 AM   #22
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
My Tundra is the 4X4 and like you stated, when you need it you need it. I have an older Reese WD hitch which came with my trailer. It has the 750 pound bars and is a very good match for my combination. I also have a friction sway device which is good, but if I were going new I would most likely get a Reese Dual Cam setup. I don't think the Toyota dealer is the best place to shop for hitches.
BTW, the Tundra / Airstream setup looks great too!
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 04-15-2008, 01:22 PM   #23
Denbear's Avatar
Eugene , Oregon
Thanx 4 suggestions, 'caster. Out of curiosity, what gas mileage are you getting (both towing & norm) ?
Old 04-15-2008, 03:09 PM   #24
Profile:
... This TV has tow capabilty TWICE the weight of my AS. Should the standard stuff suffice...?
hi d'bear
it won't be obvious till you learn more but to USE the full towing capability, weight distribution gear IS required.
azfly, and the other tundra users are good sources for set up and hitch preferences...
there was a poll recently on this issue
http://www.airforums.com/forums/f464...tch-39917.html
and LOTS of threads on each brand/type of hitch contraption....
imo for trailers with a tongue weight >500 lbs w/d equipment is important (unless the tv is 1 ton or higher rated)
and anti sway is NOT an accessory, but required.
still there are good folks here towing on the ball and with NO fancy hitch stuff...
i'm not one of them.
spend a little time browsing the hitch threads and you may learn and get confused and find the perfect hitch....
but also learn that proper loading, adequate tires (properly inflated), good brakes and controller and driver SKILLS are important too...
cheers
2air'
Old 04-15-2008, 05:01 PM   #25
Phoenix , Arizona
Images: 62
Around 11 towing. My not towing is only 15, but I live 4 miles from work and it is all surface streets. Longer trips on the Interstate take that number up to around 18, but that is at 80+ MPH.....
Richard
Old 04-15-2008, 05:48 PM   #26
Commercial Vendor
Andrew T's Avatar
Profile:  2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Denbear
Andy here from Can-Am RV. There may be some other options for you that would suite your vehicle taste better. I have not done a lot of Audi's but the ones we have set up perform very well. For some vehicles we can make a receiver here and send it for installation elsewhere but the Audi is not one of them.
It seems you are going from one extream to the other. The Audi is a tight handling drivers car and the Tundra is a tall center of gravity typical truck. There are many vehicles in between that will easily handle the 27 Airstream and get much better fuel economy.
Do you need four wheel drive?
How many miles a year do you drive your vehicle?
Andrew T is offline   Reply With Quote
Old 04-15-2008, 09:51 PM   #27
Denbear's Avatar
Eugene , Oregon
"There are many vehicles in between that will easily handle the 27 Airstream and get much better fuel economy." Andy T
The full extent of my towing experience has been with a 4.5'x8' Snowbear utility trailer. You're talking to a rookie.
I was thinking that a truck was the logical pick & was impressed w/ all that Toyota has engineered into the new Tundra. Admittedly it's tow cap (w/ 5.7L) of 10,600 is an overmatch for the 4575# dry wt of my '75. The 4.7L is rated @ 8100#, but mileage is 1mpg WORSE. Lets skip the V6. So what're a coupla quality TV suggestions, I'm all ears ... Also 4x4 not necessity & have a Miata for nice mileage.
Old 04-16-2008, 04:57 AM   #28
Commercial Vendor
Andrew T's Avatar
1960 17' Pacer
London , Ontario
Hi Denbear
It must be nice to live where you can drive a Miata year round.
There are a few vehicles that we can build a hitch for that can be installed elsewhere. The Dodge Charger RT with the Handling package which comes with 20" rims and stiffer suspension is a great tow vehicle.
On the highway both towing and solo it will outperform the Tundra any way you care to measure it, better performance handling and a shorter stopping and do it on about 25% less fuel. It is not quite the road car your Audi is but if you were to drive one I think you would find it impressive. Make sure you drive one with the performance package the standard Hemi's are not nearly as capable. You do not need the SRT8 with the 6.1 litre. It has massive power but the fuel mileage suffers and it does not cut back to 4 cylinders under light load.
The latest generation BMW 3 Series is comparable to the Audi but it has an easier structure to attach to so can build a receiver for it. It does not have the brute power of the Hemi or the Toyota but it still easily tows a 27' Airstream. Very precise handling both towing and solo.
The new Cadillac CTS with the 3.6 Litre engine is also a great handling tow vehicle. The 3.6 has a nice wide power band and gives excellent fuel economy.
I prefer a car to tow with as the low centre of gravity suites my driving style and don't see why I would drive a vehicle that handles worse than the trailer I am towing. As well when you tow with a sedan you don't burn up a bunch of power to move the tow vehicle so your towing performance can be equal or better with a smaller more fuel effiecient engine. However if I was going to get an SUV there are a couple that come close to a sedan's handling that we can build a hitch for.
The ML Mercedes is one, the new diesel has been very popular with our customers and everyone that has it loves its performance and fuel economy. The Buick Enclave has the same Cadillac 3.6 Litre and 6 speed transmission and like the ML has 4 wheel independent suspension. However the tires that come stock on it are too large for towing so we do change these to a lower profile to improve handling and performance. This is common with most SUV's and pickups these days as the perception is that larger tires sell better and I suppose they are better for serious off roading but they have too much side wall sway for towing.
If you seen another vehicle that you like the look of let me know and I can check into whether a receiver is possible.
Here is a picture of a reciever for Subaru that we shipped to a customer.
Tow Vehicle question Woodin Towing, Tow Vehicles & Hitches 1 06-23-2007 09:25 AM
Tow Vehicle question dryan 1999 - 2004 Bambi 10 08-20-2004 09:09 PM
Tow Vehicle Question SCBrat Tow Vehicles 3 09-25-2003 09:43 AM
Another Tow Vehicle Question jalewis Tow Vehicles 8 07-28-2003 01:51 AM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 11:43 PM
