Old 04-12-2006, 07:02 PM   #1
dragonflyt.o's Avatar
1969 27' Overlander
los angeles , California
new owner of 69 overlander
hi all, my name is Noel and i am the proud new owner of a 69 overlander. It is in pretty bad shape but has lots of potential. i have been going over the different threads trying to come up with a plan and trying to figure out where to begin. I think i am going for the shell off version. Why? belly pan is mostly gone, inner skins are already removed and the back of the frame needs the serious attention. so basically i am starting from scratch. I think i have figured out how to get the shell off. the part that i am getting stuck at is once i get the frame fixed which comes first 1) new belly pan or 2) plumbing( black, grey tanks) oh and gas lines and water lines 3) insulation and then floor???? i think i will need to replace the c- channel that goes around the trailer which i belive the shell attaches too. anyway i know this is a big topic but i thought it best to just jump into the forum just like i did with the trailer and see what happens. meanwhile i will keep checking the forum out. proud owner, noel
dragonflyt.o is offline   Reply With Quote
Old 04-12-2006, 07:19 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Hi Noel, welcome to the forum.
Luckily many people have already gone where you're heading, so you will get lots of help. I didn't go shell off, I did a partial floor repair, shell on.
Good luck with your project!
Stephanie
Old 04-13-2006, 06:47 AM   #3
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. There will be plenty of people willing to give advice as you go through your restoration. How about some before pictures?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 10-09-2007, 06:42 PM   #4
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Congrads...I just purchased a 68. Sounds like we are both in for alot o fun.
Aluminati is offline   Reply With Quote
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
'58 Overlander in need ! scooter 1954 - 1959 Overlander 6 12-29-2002 10:21 AM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
tree on '69 Overlander pebblepoint General Repair Forum 2 09-10-2002 06:01 AM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
