Old 06-23-2013, 08:16 AM   #1
Des Moines , Washington
New orners: 2013 Int Sig. 23D
Just picked up our new International 23D yesterday. New to Airstream and new to travel trailers as well. Always wanted an Airstream and spent the last 2 years making this decision. Went in to look at a FC20, Sport 22 and the 23FB but liked the lounge area of the 23D much better and decided to live with the smaller corner bed to get the inside sitting area. TV could not handle the 25's which had it all but are happy with the choice...just need to learn to be better (quicker) at backing up and parking which I am sure will come with time. Anyway...looking forward to time at sites and in the trailer.
Rrrobertskit is offline   Reply With Quote
Old 06-23-2013, 08:47 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome to the forum and the wonderful world of Airstream ownership. I recently looked at basically the same trailer you bought. I really liked it over the FB also. If I am ever able to swing a new trailer this will be the one I would strongly consider. I am with you on the issue of backing up. For me it has been a steep learning curve. I usually draw a crowd, maybe I should charge admission for the thrill of watching me trying to back in to a tight spot.
MICHAEL
Old 06-23-2013, 09:07 AM   #3
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
You only need practice, it'll come. There's no time limit, either; always take your time. Don't forget to take a deep bow when you finish, your audience will appreciate it
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-23-2013, 10:01 AM   #4
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Find an open parking lot, bring camp chairs as cones and practice. I used the local VFW lot. Rule #1: when backing put your hand at the bottom of the steering wheel and move your hand in the direction you want the back of the trailer to go.
SuperTrouper is offline   Reply With Quote
Old 06-23-2013, 11:16 AM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by AWCHIEF
...For me it has been a steep learning curve. I usually draw a crowd, maybe I should charge admission for the thrill of watching me trying to back in to a tight spot.
I'm in the same boat. I'm always looking for the pull through but will struggle through a back in when needed. It's one hell of a show though :-)
Old 06-23-2013, 11:17 AM   #6
W , New England
Welcome Rrrobertskit! Plenty of great insight in the forums - most important, enjoy everything!!
Old 06-23-2013, 01:02 PM   #7
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I was where you are not too long ago. I did the "back up in an empty parking lot" routine and it really did help out. I had a couple of cones to mark areas. Frankly, once you get out and just do it you'll find that it isn't as difficult as it first seems. Welcome to the Airstream family...lots of great people on here who will bend over backward to be helpful!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-23-2013, 01:32 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Leave a TRAIL for your TRAILER
Here's the Idiots guide to backing (mine). Get an empty dish detergent bottle, fill with water and draw a trail in the dirt/pavement from your driver's side back tire to the point where you want that tire to rest when you're properly parked. Then just back that one tire over the trail. If you don't have pavement and are on gravel and grass, use a generous teaspoon of detergent and about a cup of water and shake. The soapsuds trail will last about 5-10 minutes.
This technique also instantly showed me that I had a tendency to not pull forward far enough to make a reasonable (not jackknifed) turn. I also saved the rear bumper a few insults by drawing a "stop backing HERE" line when the rear of the site had obstructions.
You CAN use this even if you have to make the turn from the right side, though I try to avoid those.
If you have to squeeze between trees, or have a really tight site, get out and manually check as many times as you feel the need to do so. I don't trust the nice people who want to help - not that they are evil, but that helpers and drivers need to have an agreed upon set of signals AND walkie-talkies. Strangers with flopping hands yelling "your other left" ... not so much.
Oh, and a backup camera for the rear of the trailer - priceless!
Paula
Old 06-23-2013, 01:56 PM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sometimes it is good to have someone coach you through it- someone outside the car telling you a little left, a limitless right, hard left, hard right. You will surprise you that with someone coaching you it will go into the campsite on the first try.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
