Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 03-24-2008, 08:33 PM   #1
alisonsalley
Alisons Alley
Profile:  1976 31' Excella 500
Pleasantville , New York
Question Excella 500 Newcomer-seeking hitch ADVICE!
Hello to Airstreamers of America! Another HappyWanderer here in Pleasantville New York--but more likely found in New Hanpshire--the LIVE FREE OR DIE state! Now, this site seems like a wealth of information, please advise!
I just got a 31 foot 1976 Excella 500. We have a new Ford F150 with 5.4L and tow package with 3.73 limited slip with 7200 lb payload capacity--IS THIS GOING TO WORK?? --better question,HOW CAN I MAKE THIS WORK?. the trailer is listed at 5600 lbs.
Anyone got any advice for a newbie? Thank you!!
Alison
Last edited by overlander63; 03-25-2008 at 07:32 AM. Reason: changed fonts to forums standard
alisonsalley is offline   Reply With Quote
Old 03-24-2008, 08:37 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
I'm afaraid that your TV may be marginal, at best. Try it out, see what you think.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 03-24-2008, 09:08 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Alison
Two things you can do.
1. Get a good load equalizing hitch, with a "sway" control. that has a brain, like a Reese dual cam.
2. Put a good transmission oil cooler on the truck. However, do not place it forward of the radiator, as that heat goes into the radiator.
The idea is to cool the transmission oil, "AND" keep as much heat out of the radiator that you can.
Mounting the oil cooler below the bumper and at an angle, works great, and the heat goes underneath the engine.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-25-2008, 04:47 AM   #4
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Transmisson Cooler
I built one out of a 11''X10" Aluminum stacked plate cooler (oil), boxed it in to protect it from gravel etc, mounted underneath and it has its own fan. I turn it on when I tow and off at each stop.
No problems so far.
Beginner
Beginner is offline   Reply With Quote
Old 03-25-2008, 07:47 AM   #5
Alan Baade
Profile:  1975 31' Excella 500
Nampa , Idaho
I have a '75 Excella and I use an F-250 to tow. I've taken it from Idaho to Mexico and had no trouble climbing any hills. I do recommend an anti-sway bar and load levellers - then you won't even know it's back there... Your F-150 may be a bit lightweight so take it easy on the transmission and don't lug it down. Happy 'Streaming!
Alan Baade is offline   Reply With Quote
Old 03-25-2008, 08:53 AM   #6
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
You might even find a used Reese sway bar type setup on EBAY. It will make a big difference. The trailer may already have parts for it on the tongue.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Newcomer Looking for Advice kbinder Member Introductions 5 03-04-2007 04:04 PM
77 Excella 500 Brake Advice needed tschat Brakes & Brake Controllers 2 06-14-2006 11:55 PM
Newcomer needs advice! Lianne Our Community 8 05-02-2005 12:22 PM
Desperately Seeking Hipster Fulltimers/Advice! iamsusanq 2005 International CCD 17 12-08-2004 08:50 PM
Seeking Advice.... jtshipp On The Road... 9 05-17-2004 04:42 PM
