Old 07-02-2007, 08:55 AM   #1
New York , New York
new member with questions....
Hello. I'm a new member who is interested in purchasing an airstream. I'm a complete novice and am hoping to get an education and help through this web site. For example - can someone please tell me the size of the smallest/narrowest trailer and whether my mustang convertible (1990) will be able to pull it?
What sort of price would such a trailer be: used? new? features which I should have? And has anyone ever shipped an airstream to the UK (where I live). How much does this cost?
Thanks in advance for all your advice.
leica is offline   Reply With Quote
Old 07-02-2007, 09:01 AM   #2
dudebb's Avatar
1962 16' Bambi
Newtown Square , Pennsylvania
Hi Leica and welcome to the forums!
I'm no expert, but there are many here who can advise you on this. I would be very careful in trying to use the Mustang as a tow vehicle. Length and weight play a major role in the tow vehicle capabilities along with power. I have what may be one of the smallest and lightest Airstream models (62 Bambi) and I would not even think about towing it with the Mustang - but let's see what the experts have to say.
Good luck in your search and again, Welcome!
George
dudebb is offline   Reply With Quote
Old 07-02-2007, 09:17 AM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Leica,
The smallest Airstreams are usually Bambis. They're in the 16' single axle range. New trailers (mid 90s and later) are much wider and heavier then vintage models. I will pass on giving you my opinion of towing with a Mustang but it is all in the numbers. What does Ford say the towing capabilities (weight it can tow) of a 90 Mustang are? Also towing will put much higher then normal stress on brakes and transmissions. You might need to change your final drive/gear ratio (rear differential) to improve tow capabilities.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 07-02-2007, 10:19 AM   #4
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
vintage
The smallest lightest might be a vintage Airstream Argosy Minuet 6.0 metres. It was a very lightweight model produced in the 70s. I don't know if it could be pulled with a Mustang, but I am sure that there are some folks here that can chime in with further info.
Welcome to the Forums!!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 07-02-2007, 11:30 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us.
The really short wheelbase of a mustang makes it a less than desireable tow vehicle for any trailer. I'm afraid that pulling any Airstream with a Mustang would be an uncomfortable experience.
SuEllyn & Brian McCabe
Old 07-02-2007, 11:42 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Welcome to the forum! Yo ucame to the right place for information and you will find that there is plenty here to be had. When it comes to tow vehicles (TV's) there is much discussion here about how big a TV you need. You will find the majority of us feel very, very strong about safety to yourself and others when towing and the bigger your TV the safer you are going to be. As for your question, I would say a ford Mustang is not designed to tow anything let alone an Airstream. Suew big beefy 5 L and all that but the frame isn't there, the wheel base isn't there and the transmission wouldn't last your first trip of 2,000 miles. And as my fellow forum member mentions, once you get it rolling, you gotta stop it and believe me, there are many forum members here who have forgotten that. Again welcome to the forum and have fun!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-02-2007, 11:48 AM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greeting leica!
I don't know how much the Mustang convertible changed between 1986 and 1990, but I do know that my 1986 Mustang 5.0 Liter GT Convertible carried a maximum tow rating of 1,200 pounds. If the 1990 was the same, you won't be able to find an Airstream that your 1990 Mustang can pull. The 1961-63 Bambi would be among the lightest at approximately 1,625 pound empty weight; the Argosy 6.0 Metre Minuets had an empty weight of approximately 2,400 pounds. If you look back to the 1950s, even the 16' to 18' coaches of that era had empty weights that would be in excess of the likely trailer tow rating of your Mustang convertible.
Something else to keep in mind with the Mustang convertibles of the era that you mention is that they were essentially factory-produced customs -- made by reinforcing the unit-body sub structure and cutting off the coupe's roof and installing the rear side windows and convertible top mechanism -- the propensity for cowl shake would be greatly amplified by adding the weight distributing hitch that would be required to tow an Airstream.
I wish that I had better news for you.
Kevin
Kevin D. Allen
AIR #827
Member Titles, what do you think? Andy R Forum Admin, News and Member Account Info 17 08-18-2007 09:13 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Help for new member... Cheryl 1978- 1979 Excella 500 23 12-31-2002 08:40 AM
Member reviews now available! Andy R Our Community 4 07-20-2002 10:34 AM
