Old 09-05-2007, 12:41 PM   #1
1984 31' Excella
Willamina , Oregon
new member with problems
Hello everybody,
My user name is mxsounds and I am a retired Motion Picture editor. I purchased a 1984 31' Excella trailer and living on a piece of land in Oregon.
My black water waste tank is 3/4 full and when I pulled dump valve to empty nothing came out. Can anybody tell me what is wrong? Is valve screwed up or can opening just be plugged and if so how do I unplug?
mxsounds
mxsounds is offline   Reply With Quote
Old 09-05-2007, 12:47 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. The area at the valve can be blocked with solids. You may be able to loosen the solids by opening the valve, and spraying hard with a water hose. Be aware that if you succeed in breaking the dam, you will have a lot of "stuff" quickly flowing out.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 09-05-2007, 12:47 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Uh oh!
Sounds to me like you have a plug...either that or the handle pulled off and the valve was not opened at all. Did any "water" come out at all when you opened the valve? If so, and the solids remained it's a plug and you just need to dislodge it - carefully!
If nothing at all came out and the handle moves very easily, not at all or it doesn't go back all the way, my guess is the valve is broken or jammed.
Regardless, there is no easy solution - especially with a 3/4 full tank
One thing we have found is that if we use "normal" toilet paper it will clog up easier than if we use the thin single-ply or RV toilet paper which breaks-up and dissolves better between dumps. Not as luxurious but certainly better than dealing with a "plug" or "cone".
Sorry I can't be of more reassuring assistance...but welcome to the forums!
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-05-2007, 12:48 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Did you contribute to the fullness so your sure something is in there. If your going by an indicator panel it's most likely wrong.
Old 09-05-2007, 12:49 PM   #5
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Take your hand and run it up....OK just kidding...
It does sound like you have something blocking your drain valve...could be some tissue or other foreign matter...there are lots of threads about this same problem...I would use your search tab and see what you can find...
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 09-05-2007, 12:53 PM   #6
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Here's a link...
G
http://www.airforums.com/forums/f444...ank-31189.html
877-Air-hog1
877-247-4641
AIR #8844
Old 09-05-2007, 01:15 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I would pour a bunch of septic tank enzyme in there. It wont hurt anything, it may solve the problem, and it will let you put off dealing with what will probally turn out to be a crapy situation
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-05-2007, 01:21 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by mxsounds
Hello everybody,
mxsounds
As noted earlier, how are you determining that it's 3/4 full? Are you going by a gauge or have you looked down into the toilet with a flash light? Obviously if you are using the eyeball technique and visually see the liquid, the folks here have already addressed the clog situation. I'm also assuming the valve is functional.
Once you address this situation, remember to always try to dump the tank when it has ample liquid in it. Don't ever leave it open constantly since that will allow solids to build up within the tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-05-2007, 01:28 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
It sounds like a blockage, and this is a very nasty problem... But others have had it and have dealt with it in a number of ways...follow the links provided above and you'll find several options to try...and what others have done to resolve it.
It's unclear if you've been doing this, but it's really important to not let the black water drain valve remain open all the time...let the holding tank fill up before you dump it... If it's left open, there's not enough water in each flush to wash the solids out the drain, and the potential for solid waste build-up happens as the liquid drains out and the solids stay behind. If you let it fill before you dump it, the force of a full tank draining will get rid of most of the solids when it drains. Rinsing a couple of times after dumping is a good idea, too...
Good luck with it...
TB
Old 09-05-2007, 01:30 PM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Another possibility, if you are mobile, is to put a bag of ice into the black tank via the toilet. Drive around until the ice has melted. The ice being solid will help break up solids and then melt. Just watch out for the 'black ice'.
Rodney
and the
My Blog
Brake Problems On 345 for New Member jagcb750 Classic Motorhomes 38 11-25-2009 06:06 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
Air bag problems...help! Mike Leary Jacks, Stabilizers, Lifting and Leveling 1 04-06-2007 11:08 AM
AC Problems PhiDor Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-11-2006 08:11 PM
