Old 07-04-2007, 11:08 AM   #1
1969 31' Sovereign
Spring , Texas
New Member with a Problem
Howdy from Texas. I have 1969 Land yacht, fully restored and in use as a second home on our Farm. Unfortunately, the Fridge is on the fritz, works on gas, but not on land power which we have been using continuously for the past 6 six years. Have I done something to my baby or is she sjust getting old? I have the manual, but it does not seem to cover this particular problem. Would appreciate any advise on how to it working again. I keep thinking that since it works fine on gas, it is something minor, a relay or sensor I don't know about....
mmueller is offline   Reply With Quote
Old 07-04-2007, 11:13 AM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
It sounds like your electric heating element went bad. Maybe someone with more experience with such things will chime in here.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-04-2007, 11:14 AM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Welcome and practiec "The Search"
Welcome to the Forums! As a new member, you now have search capability to find thousands of existing messages in archives here which will address your issues...
Practice learning and using the "Search" tab above in blue bar.. Just click on it, and type in key words like "dometic" and "110" or "electric" and "element", etc.. You'll find threads and eventually messages of others before you with similar issues..
In the meantime, it could be a fuse, or the heating element, or the control board that directs heat to the element, or possibly bad flue preventing the heating element from heating the ammonia mix hot enough...
You may get more info also by posting updated message with make and model of refrigerator, and a photo or two of back side..
Good luck!
Condoluminum
Condoluminum is offline   Reply With Quote
Old 07-04-2007, 11:24 AM   #4
1969 31' Sovereign
Spring , Texas
no ice in Texas
thanks Chris. Maybe someone out there can help me with this one. too hot not to have ice... by the way, my names Mike thanks again for jumping in .
Old 07-04-2007, 12:06 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
MIKE..
Here's a site with basic info..I suggest two things, first check ur flue and be sure no critters have set-up home there..(Cheapest things first). Then, I have to agree C.JOHNSON, that. Your electrical heating element may have just simplified burned out after 6 yrs of continuous use. The very last thing..Actually two things. Check ur fuse box and, have ur battery checked. Make sure that's up to full charge..The 12v is used to power the frig control board ..Got that?
Good luck~!! mat all your problems be solved with ice~!~
ciao
53FC
Bryant RV Services
a troubleshooting page..
Bryant RV Services
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-04-2007, 12:13 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Another Possibility
Hi Mike,
Welcome to the forums. I had a similar problem with my 67 a couple of years ago. I turned out that one of the connections at the thermostat was corroded. Try cleaning your connections. At least itís free.
Vaughan
Old 07-04-2007, 03:46 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The easies thing to check would be the circut breaker for the outlet the fridge is plugged into. If not that I would look at the heating element. Disconnect the wires and check it with an ohm meter. If it shows open it is bad.
Richard
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
Member Titles, what do you think? Andy R Forum Admin, News and Member Account Info 17 08-18-2007 09:13 PM
Elec. problem again! davidz71 Electrical - Systems, Generators, Batteries & Solar 48 03-13-2005 05:37 PM
Opps... (Split thread problem) Andy R Our Community 1 10-19-2002 02:12 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
