10-17-2017, 08:49 AM
Tampa
New Member planning 3 month adventure with 2 young kids...
Hi everyone. Been lurking around here for the past 5 months or so collecting info and researching. We are a couple in our mid 30s with a 3.5 year old and about to have a newborn.
We plan on embarking on a 3 month journey 'interviewing' cities to resettle and plan on doing this by airstream. If all goes as planned, we plan to push off in Mid january - early february and spend 2 weeks in and around the following 6 cities:
Boulder, CO
SLC, UT
Boise, ID
Seattle, WA
Reno, NV
and lastly
Bay Area, CA
Having the same place to call home along our travels inspired the idea to use a travel trailer on our adventure. We like the idea of routine as parents and thought that the consistency of a trailer would be a good idea rather than Airbnbs and repeatedly packing and unpacking each time we moved. We are thinking of purchasing a 2015+ 25FB and selling it in a year or perhaps keeping it to continue to adventure once we relocate.
Just wanted to make an introduction and welcome any input (both positive and negative) as we continue to plan our journey. Thank you to all community members who have shared all of the valuable information here.
10-17-2017, 10:03 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Sounds awesome. Just watch freezing weather in some of those places.
@living.somewhere.yonder | Instagram
10-17-2017, 10:10 AM
Tampa
Yeah. I have been reading through many of the winter camping threads here. From the sounds of it, oversize LP tanks, a heated water hose, and a dehumidifier, I should be ok.
10-19-2017, 08:12 AM
2014 30' FB FC Bunk
Anywhere
What's your camping/rv experience? What you are suggesting is doable, but will be a big learning curve. Start in warm weather.
And I'd skip the heated hose. Just fill your tank in the daytime and disconnect.
10-24-2017, 07:38 AM
Tampa
I've camped a fair amount throughout my life. Id consider myself the 'outdoorsy' type. RV experience is NIL. I am mechanically inclined and handy, however. In terms of my interests, I believe this to be right up my alley. That said, I am anticipating hiccups, as always.
I am unfortunately unable to embark in warmer weather due to timing restrictions. I realize that this is sub optimal but I've read its possible.
Thanks for the advice on the heated hose. Keeping the tank topped off sounds like a reasonable alternative.
10-24-2017, 10:10 AM
Normal
If you are new to RV’ing, heading way north with two very small children during winter months might not be the best plan.
Managing extreme cold, snow, ice, storms, etc, is challenging for seasoned RV'ers.
Aside from the possibility of freezing up, roads close regularly, and have you checked on availability of open campgrounds?
It may be what you want to do, but is it safe for the very vulnerable little ones?
I advise against doing those northern states during winter months.
Maggie
10-24-2017, 10:22 AM
2012 25' FB Flying Cloud
Parker
I live in Denver and have a couple of warnings:
Once you make it here, and Boulder is very pricey to live, you have 2 choices on routes to get to SLC. I've done both. Go the flat route and head north to I-80. Don't even think about it. Wind and black ice are not your friends.
I-70 over the mountains. 2 11,000 ft passes you need to wait for good weather. If you haven't towed before these can be challenging. It's all about the downhills. Gear down, and use your trailer brakes.
Me - I don't travel with my Airstream in the winter except to head south on I-25 to warmer weather. I can't recommend your plan with 2 small children but there are campgrounds with hookups open in the winter. You just need to research well. And carry a Mr. Buddy ceramic heater for backup.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
10-24-2017, 10:50 AM
Sag Harbor
, New York
Warning -- inclement parade weather ahead . . .
For most of this trip, due to weather and altitude, you may be towing around an aluminum tent, without running water and toilet facilities. If you are lucky when you hit freezing weather, you will have already drained the plumbing, and will not have to repair broken pipes inside the walls and floors.
Is this "dry-camping aluminum tent" picture consistent with the dreams in your heads?
Just one of many factors which, in my personal opinion, make your proposal seem unrealistic for Feb/Mar/April. Ditto to recent comments, and others sure to follow IMO.
Sorry to rain on your parade, but there has to be a better way to find work, at least during the winter.
Good luck,
Peter
10-24-2017, 12:05 PM
Walnut Creek
Just about everywhere it is possible to travel from one Full Hook Up park to the next if you pick a weather window and hit it on both ends. The problem here is that travel on a schedule is a very dangerous way to travel as you get sucked into traveling when you should be parking.
Travel with a plan. As stated prior, verify the parks will be open and have at least one back up in the plan. Keep reservations to minimum to allow flexibility in travel plans. Travel with no less than half fuel states - propane and TV fuel. Regular stops are a good plan.
If you have not towed before, you have a lot to learn. Pick your route carefully. Go to fuel stops without tight pump islands. Wait for a good one to open. Watch for holes, drop offs, blocked exits - folks park in the most inconvenient places. Travel slow. Wait for black ice to clear. Stop early for the night. Transition Metros outside commute hours. Travel early when you can. Expect 200 miles to be a good day.
Towing is a full contact sport. You need to drive 10/10s with full concentration and situational awareness all the time. Navigator is as important a function as driving. It's a partnership. A second set of eyes, a second brain to solve route selection in poorly marked interchanges, and identification of lane change requirements all help to reduce stress, improve safety and improve the process. Get a GPS with lane requirements shown. A heads up display on your TV is a very big help. Keep a paper map close at hand as well as the campground information resource.
Consider having a generator as a backup plan. Given a good fuel management program it will fill in park availability short falls.
Carry chains - it's an insurance policy you don't want to cash in on, but as a last resort, it can get you through to a safe location. Storms do come up without warning and forecasts can be wrong - see below.
There is a lot of noise about tires. The 2015 GYMs are likely not flawed as earlier ones may have been. However you are going to travel many miles.
Do it on new tires and maybe new brakes/bearing repack. Research well before you buy and install a TPMS. Do it!
An Airstream is a great coach. However, it is not a four season design. If you were not traveling so much, I'd suggest a four season design. If you settle North, you may wish you had. Be prepared for using that dehumidifier and lots of fuel. An electric quartz heater is likely a good addition to the Buddy.
Metro areas often do not have great RV Parks. A plan (reservations) is the key, but even so, you may get to experience the traffic and commute options. Brother has developed an approach where he reserves a couple of days and if he can't extend they will dry camp for a short period. Considering cold weather threat, that could get you into a bind. In warmer areas it works well.
Winter roads get treated with sand and chemicals to maintain traction in bad weather. Not always good for the life of a trailer and tow vehicle. Certainly, a negative for a coach you want to resell. Plan on lots of washing the undercarriage. Hitch wear surfaces will need more frequent cleaning and lubrication. Caution, brakes may grab a bit after a wash. Treat umbilical contacts with dielectric grease.
I would use a good car and hotels. Money ahead, more time on task, less work, and safer too. That could be a very special trip for the family too.
Good luck with your plan. Research is great - do a lot. Pat
10-24-2017, 12:22 PM
Mantua
, Ohio
Are there rv parks open in the winter out west? I see you are from florida, do you hgave any experience incold weather?
10-24-2017, 12:37 PM
Sag Harbor
, New York
PS - The Winter Living forum would be a good place to research that aspect of your plans. Being aware of the weakest link in the chain is always a good idea.
http://www.airforums.com/forums/f462/
Also, the new search function above with the blue border works great.
Winter Living: https://www.google.com/search?q=Wint...=airforums.com
The AccuWeather.com monthly forecast charts have a helpful line graph at the bottom, with the average high/low, and forecasted temps, which have proven to be fairly accurate IMO. For instance Denver for January:
https://www.accuweather.com/en/us/de...monyr=1/1/2018
[scroll down to bottom of page]
COLD!
You can change locations fairly easily at the top of the page. Months later than January will be available as they get closer in time.
Good luck.
Peter
10-24-2017, 12:47 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Freezing weather does not just impact your trailer. It also impacts the water and sewer setups at campgrounds and dump stations. Up here, they start shutting down water and sewer at this time of year. They start re-opening those facilities in the spring. Exactly when what is shut down or opens is highly variable. They may be open through December at one place. At another location a bit further up in the mountains, the end date may be the first week of November.
Having blown up a transmission on I-70 west of Denver in the middle of the winter, I can indeed attest that "stuff happens". Trips do not always go as planned. Stuck by the side of the road in the middle of Ohio with a frozen engine, a 6 month old, and heavy snow also was not much fun (toss in that this was before the cell phone era as well - you got out and walked a couple of miles for help). You need to plan with some margin for issues.
One can never predict a winter in advance. In parts of the country you are talking about, March can be a heavy snow month. It may be rain down low, but you can't always stay low. You can't always be sure of what the split between rain and snow will be altitude wise. The weather man often is wrong. Planning to get through here or there can be tricky. As mentioned above, snow and freeze are not the only issues. High winds are also a very big deal.
Is this un-doable? Nobody knows at this point. The odds improve if departure is in mid March compared to mid February. Odds improve a little if you stay south for as long as possible. Altitude generally works against you, but not always.
Do have chains for your TV and trailer. You are likely to run into areas where they could require them.
Lots of fun !!!
10-24-2017, 01:39 PM
Sag Harbor
, New York
Well said, Bob.
" . . . before the cell phone era . . . ?"
10-24-2017, 03:08 PM
Tampa
Im actually born and raised in Ontario(Canada) and have spent most of my life there. That said, I am no stranger to colder weather and more importantly winter driving conditions.
I will certainly have chains.
Originally Posted by OTRA15
Thanks, ive seen the above posts and a few more. Seemingly there are airstreamers out there that are successfully using late model trailers without winterizing them as long as they're kept warm the entire time. LP consumption is high. Was thinking to retrofit with larger LP tanks. Regarding average high/low temps in the areas I plan to visit, I've looked at historical data. Its the cold snaps you have to look out for, it seems.
Great post, thanks, Pat. My research continues. Will look into the remote TPMS. Good idea. Though I have no experience towing travel trailers, I have been towing boats and utility trailers most of my adult life.
Do they treat roads in the areas I plan to travel as they do in the salt belt? I was under the impression that they didn't.
I am about to begin to look at travel parks in the areas of interest that offer winter camping with hookups. Does anyone have a recommended resource for this or am I best to pick up the phone and call around? I checked with goodsamclub.com and unsurprisingly, their search feature doesn't allow me to query 'winter' camp sites exclusively.
Thanks to all for the continued input. Its appreciated.
10-24-2017, 03:15 PM
Normal
The AllStays app is good for finding RV parks.
Maggie
10-24-2017, 03:45 PM
Open field
, Idaho
Can't comment on much regarding the trailer side of things but I can give you some locals experience on winter weather in the ID area. It Sucks.
The main route across WY from Boulder to SLC is often closed intermittently throughout the winter months. If you are headed that way and see all of the Semi Trucks parked, stop and do the same. The wind blows hard across southern WY and black ice along with snow drifts and extreme wind make that route very dangerous in the winter. As others have said 70 through the center of CO is not a lot better. My Brother drove truck for a few years and would often route way south during the winter months to avoid crossing WY.
The Blue Mountains in east OR are another area that regularly closes the route from Boise to Portland in the winter months. Now some years winter is winding down in mid February, last year it was just starting. We had months of snow storm after snow storm after snow storm. Over a foot dropped overnight multiple times. Think we kept the kids home from school and did not go into work on 6 separate days last year...all of them after mid January....and into March. Many city streets were impassable with snow and ice for weeks...road crews could not keep up.
Boise also tends to get winter inversions...It sits down in a bit of a valley and it looks like fog/smog for weeks on end. Not to be discouraging but it sucks here in the winter. If I could spend winter (November till May) anywhere else I would. And this winter is getting an early start...low temps are already below freezing most mornings, snow in the foothills and some very high wind nights.
10-24-2017, 09:06 PM
2014 30' FB FC Bunk
Anywhere
I'm thinking an air bnb in each city might be your best best. It's only 3 months. Get a trailer later.
10-24-2017, 10:49 PM
Walnut Creek
The posted picture is beside I80 about an hour East of Salt Lake. We hit sand and chems about an hour to the East. But if you never see any, so much the better. Best way to insure that is to stay parked in such weather.
Looking at specific park web sites helps with planning. The opening and closing dates are usually posted. Take a bit of care on general sites like RV Parky. We like it, but got some bad info and wasted some time looking for closed parks. Some parks close earlier than advertised so check with a call.
Boulder, CO
SLC, UT
Boise, ID
Seattle, WA
Reno, NV
and lastly
Bay Area, CA
Run the list in reverse. Head directly for San Francisco by way of either I10 or similar Southern route. You will learn a few towing lessons along the way.
It's a four hour drive up to Reno from the Bay area. If weather is bad, you can dead head with just the tow vehicle.
Then run up the Coast to Seattle. It's warm along the coast and interesting scenery.
By that time you have bought yourself some better weather. Head to Boise, then Salt Lake and last of all run over to Boulder.
Pick your weather windows carefully.
Also, look at Portland, OR - nice place to raise a family and Missoula, MT - the banana belt of that area.
Good Luck with your planning. Pat
10-25-2017, 12:05 AM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
We are familiar with several of your destinations and would not do this trip in winter towing a trailer. Winterizing is important. You might get by in an RV park without winterizing, but you'd have to tow with your furnace running when daytime temps do not get above freezing. It's safer to winterize and you can camp that way, but then the RV gets a lot less habitable for a family.
When you're moving you won't be in an RV park, so do think about your water lines then.
The main problem would be driving on icy, snowy roads. Yes, one should remain stationary and just hole up during such conditions, but sometimes in the West this is a lot less feasible than one would hope, if the weather should change on you, due to long distances between exits. I drove that stretch of I-80 in Wyoming in winter once and it was a frightening experience due to severe ground blizzard conditions. The skiers and truckers routinely use I-70 in winter, but it can be serious winter driving.
I grew up in snow country and drove a lot in winter conditions, but nevertheless once had an accident on I-80 east of SLC in a stretch where rain in the valley turned to snow in the mountains, and the pavement turned into a skating rink.
The roads will either be salted or icy when it snows. Oh, and beefy snow tires are essential, not the "all weather" tires sold in the South.
Maybe there is an RV park near Boulder now, but there wasn't one anywhere close by when my son lived there. I should think it would get a bit demoralizing making do with Walmarts and Flying J truck stops.
Sorry to sound so discouraging, but hey-- if you're going to be an Airstreamer, we don't want to lose you.
10-25-2017, 05:39 AM
Sag Harbor
, New York
Bingo!
This is the best approach IMO. Let the weather be your guide from SF. North to Portland and Seattle with the trailer, with dead-head options to go east as needed.
Have fun!
Peter
