Old 10-16-2014, 07:56 PM   #1
2009 27' FB Classic
Lincoln , Nebraska
new member needs advice on buying used
I've been reading quite a bit on the forums about different issues with the airstreams have but one in particular issue seems to be floor rot. Are there certain years that it is more prevalent. We're interested in 2007 to 2010. Any advice would be appreciated.
79fasteddie is offline   Reply With Quote
Old 10-16-2014, 08:56 PM   #2
SteveH's Avatar
Common Sense , Texas
Floor rot is a result of water leaking in and usually traveling down between the inner and outer shell till it hits the floor. The newer the trailer the less likely to find floor rot, with the exception of some of the FB models had consistent problems around the door area.
Other than going around the perimeter of the floor and checking for softness with something like an ice pick, and then only on carpeted areas, I know of no other way to check for it.
Regards,
Steve
Old 10-16-2014, 09:52 PM   #3
2008 27' Safari FB SE
Akins , Oklahoma
Images: 20
1. Floor rot particularly on the rear because of the unsealed joint at the top of the trunk behind the belt trim.
2. Volunteer to wash it. You'll find everything on the outside.
3. Check the belly for rubbed through rivets. It shakes a lot because the tires are not balanced and neither are the wheels
4. There is probably an inspection list on here somewhere
5. Leaks on the belt line where water runs off the sides of the awnings and down the side.
6. Most leaks you can't see because AS installs the floor before the furniture so the leaks are hidden by the vinyl or carpet
7. Hidden bottom damage, particularly the tanks because AS is so low to the ground. Check all the drain petcocks
8. Be sure you get all the owner's manuals
9. Check for and get all the keys for all the compartments
10. Check for a leaking sewer valve
11. Test the appliances
12. Test the converter and inverter. I find they are notorious for lose connections that buzz
13. Tell tale leak trails of white oxidized aluminum down from the windows on the inside
14. Tire dates
15. Refrigerator in all modes
16. Vent covers condition on the roof
17. Antenna crank operates smoothly and antenna goes up and rotates well
18.
sequoyah101 is offline   Reply With Quote
Buying a used 3/4 ton diesel.....advice? Texasdiver Tow Vehicles 61 02-16-2014 09:23 PM
Buying used Interstate, need advice weirdstuff Sprinter and B-van Forum 74 11-18-2013 08:43 AM
Buying gently used vs. less gently used?? PharmGeek Buyer Guidelines 24 06-14-2013 07:41 PM
New member - needs advice on airstream purchase HeidiGJ Member Introductions 4 06-06-2012 08:56 PM
New site member needs advice NOAZRK2690 Member Introductions 6 07-24-2009 08:11 AM
