Greetings samwise!
Welcome to the Forums!
Originally Posted by samwise
Hi, I am looking for a vintage trailer. Just retired and don't need a second mortgage.
I have a 2008 Silverado with a z71 package which includes the HD towing package. It has a 5.3 liter v8 and a 3.73 rear axle. I am looking for a tandem axle trailer. If my calculations are correct the upper limit would be a 28 ft Argosy or Airstream. Although I would prefer a something less but with tandem axles.
One of the first things that you need to determine IMHO is the trailer tow rating for your truck. There is something of a consensus among some of us on the Forums that it is best to take 80% of the factory trailer tow rating of the tow vehicle as a target GVWR for the coach to be selected. There will be a large number of Vintage Airstreams and Argosys within the trailer tow capabilities of your truck, but there will be a modest reduction of the selection with the tandem axle requirement.
With the first generation Argosy coaches (1972-1979), the Argosy 20 was the only single axle coach through the introduction of the Minuet series in 1977. When Argosy introduced the Minuets, the 6.0 Metre Minuet (20') and the 6.7 Metre Minuet (22') were both single axle coaches.
With Vintage Airstreams the lengths where tandem axle coaches began varied with Vintage, and often the same coach could be ordered with either single or tandem axles . . . there were periods of time when both the Overlander (26') and the Tradewind (24') could be had as either a single or tandem axle coach in the same year. Beginning in 1965, the Tradewind adopted standard tandems as had the Overlander several years earlier . . . this made the Safari 22' the largest single axle. Sometime in the 1970s, the 22-foot Airstreams adopted tandem axles making the Globetrotter (20' or 21') the largest single axle. These are generalizations for Vintage Airstreams and I am sure that I have probably overlooked one or two exceptions to the general rule.
The above of course is an approximation. Looking at the vintage floor plans and specifications I have noticed that tongue wait on some shorter models are heavier than on some longer models of the same year.
The tongue weights as published can vary for a number of reasons, but one thing that is consistent among nearly all of the Airstreams is that they were well-balanced from the factory. Part of the excellent towing manners of an Airstream can be attributed this balance and the fact that at least 12% of the coach weight is carried on the hitch . . . and on some models this can approach 15%. My '64 Overlander has a loaded ready to vacation weight is 6,100 pounds with a hitch weight of 745 pounds while my Minuet has a ready to travel weight of 3,100 pounds with a hitch weight of 525 pounds. My Overlander hovers around 12% of the coach weight on the hitch while the Minuet has a little less than 17% of the coach weight on the hitch. Generally, I believe that you will find that most Airstreams will fall somewhere between 12% and 15% of the coach weight on the hitch.
Has anyone accurately calculated what a tow vehicle like mine can comfortable tow? When I bought it the biggest thing I planned to tow would have been a 17 foot Boston Whaler. I am concerned for long extend hauling through the Rockies the tow vehicle maybe a little under gunned.
The best starting point that I can recommend is the factory trailer tow rating for your vehicle. If this isn't stated in the papers that you have for the truck, your Chevrolet/GMC dealer should be able to assist in deciphering options to determine the factory trailer tow rating. You will find that there are a number of us here on the Forums who suggest staying about 20% below your tow vehicles maximum trailer tow rating when looking at the GVWR rating of coaches that you are considering. The closer that you are to the maximum trailer tow rating, the more compromises you are likely to uncover in your tow vehicle.
Good luck with your investigation and search!
Kevin
P.S.: If you are looking at a Vintage Airstream and want to learn more about its configuration, you might want to check this
link on the Airstream website.
