Jimmy,
Welcome to the forums and to Airstreaming from Pennsylvania. We're sure you'll enjoy the travel and adventure.
Yes your 15 amp service from your home should run the refrigerator without a problem. You'll want to use a suitable extension cord depending on the length needed. Typically for the refrigerator and converter (charges the battery and supplies 12vDC systems) the type used for outdoor power tools should work (14 gauge). If the run is very long you may need a heavier (12 gauge) cord. If not supplied with the trailer, you may need an adapter to go from a 30 amp outlet to a 15 amp outlet. They're inexpensive and available at any RV store, WalMart, most big box hardware stores, etc.
Have fun and hope to cross paths with you sometime in the future,
Roy and Marie
