Old 06-23-2015, 08:16 PM   #1
1964 17' Bambi II
Bloomfield Hills , Michigan
new member from Michigan
Hello My name is Damon. My dad and I are in the process of restoring his 1964 Bambi II. Neither one of us have ever had a trailer of any kind befoer he purchased the Bambi II. I figured we should post our build here to start and see if we're headed in the right direction with our plans.
We removed the interior down to the framing by gently removing the 8 million rivets.
So far my dad took the damaged passenger side wheel well to have remade and ordered new 5/8 plywood for the floor.
I've been cleaning out the 50 years of evaporated rodent pee off the skin... spent about 6 hours last weekend just cleaning the inside of the skin off. Hot water.. spic and span and a scrub brush. Doesn't seem to work the best either.
Next thing we need to research and get advice on a few things.
What insulation to use under floor? spray foam, bat or hard foam?
Reflextix.. or reflective insulaltion on walls?
We also need to research how to rewire and plumb it to updated. So I'll be looking for wiring and plumbing plans a diagrams understand it better.. Pex.. or copper type questions?
Thanks for the help.
I've learned quite a bit reading so far.
Cheers.
Damon
DadsBambiII is offline   Reply With Quote
Old 06-23-2015, 09:17 PM   #2
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Damon,
Your project sounds all to familiar. The Bambi 'll is a really nice trailer. I didn't place any insulation under the floor because of the rodent problems mentioned. We have spent a few nights with temperatures below freezing and a cold floor will be the least of your problems. Those walls get mighty chilly. Keep us posted on your progress and buy lots of 1/8 drill bits.
Tim
Beaker63 is offline   Reply With Quote
Old 06-23-2015, 09:34 PM   #3
richw46's Avatar
Lexington , Kentucky
Hi Damon, welcome to the forum. Good luck with the restoration.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-23-2015, 09:45 PM   #4
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
Hello from Baroda MI. We are also MI newbies with a new FC30 which should be hitting the road next spring. Welcome.
DuncanK1 is offline   Reply With Quote
New Member, New Bambi 16' & New Tacoma TV Mageliza Member Introductions 12 05-25-2015 05:21 PM
New Member from Michigan Plan-B Member Introductions 4 04-23-2015 06:02 AM
New member, New Airstream, New life. TikiDaddy Member Introductions 10 07-17-2012 10:07 AM
new from michigan dean tighe Member Introductions 11 09-11-2007 10:35 PM
New from Michigan's "West Coast" Sunset Coast Member Introductions 11 03-27-2007 07:54 AM
