Old 01-11-2006, 09:39 AM   #1
new member - 76 Caravanner info plz
Can anyone help me find a floor plan for the 1976 caravanner? Also, the refrig works on gas but not electric. Whats wrong?
Thanks - "Hook 'em Horns"
Longhorn57 is offline   Reply With Quote
Old 01-11-2006, 12:35 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Go to www.vintageairstream.com and scroll down to the Archives and click on that. Since I am in Oklahoma, I will over look the "Hook'em Horns" remark. Don't know about the frig. problem, but I'm sure someone on here can help you with that. Welcome to the Forum. Lots of good information here, even for a Texan.
juel is offline   Reply With Quote
Old 01-11-2006, 01:41 PM   #3
1976 25' Caravanner
kingston , Washington
76 caravanner
Its good to see another 76 caravanner out there.
Had the same problem with my fridge. Turned out to be the AC heating element. Don't remember the specifics but will look in my service manual tonight. I will post the information I have. The very worst problem is getting the fridge out. That job comes with a few well chosen words. But its do-able.
If I remember right my service manual didn't have the floor plan; again, I will look for that.
If you post your phone #/address I will get the stuff to you.
Jim k
jim kolhoff is offline   Reply With Quote
Old 01-11-2006, 05:02 PM   #4
Darol Ingalls's Avatar
I've regretted selling my '76 Caravanner ever since the new owner towed it away, but at least it went to a good home and I still get visiting rights. The floor plan was not included in the '76 owner's manual, don't know why, but there weren't many made. Refrigerator problem is likely the 110volt heating element since it works with gas. Hard to get to without removing the unit since there is no outside access door and the side access is for elves. Four bolts through the floor accessable from underneath the trailer. There should be a removable aluminum panel next to the vent screen. They are probably rusted on, so you'll need someone inside the trailer with a wrench on the bolt heads. Then there are screws on the side panels along the front edge and probably along the back edge that must be removed before the unit can be removed. I made a bracket to hold the fridge above the wheel well and moved it back closer to the wall to allow more space in the hallway. Of course, that was done during a complete interior rebuild. Good luck. Darol
Darol Ingalls is offline   Reply With Quote
Old 01-12-2006, 10:48 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I am assuming that you checked the outside compartment and the receptacle in that compartment where the refrigerator plugs in has power?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-12-2006, 11:24 AM   #6
1976 25' Caravanner
76 Caravanner
Here's the information I have from my 76.
When my fridge stopped making cold, I went to the local RV parts place and bought a "universal replacement" heating elememt, #NW39-6114. relatively inexpensive. Important thing is that it is 225 watts; will measure about 52 ohms. That was 7 years ago and it works great.
I have a floor plan diagram if you need it.
Jim K
Old 01-12-2006, 11:26 AM   #7
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Try this link - no floor plan - but lots of pictures
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-12-2006, 10:46 PM   #8
davidz71's Avatar
1986 25' Sovereign
Caravanner
I'll tell you, I love the looks of the '76 Caravanner. All those windows. It has the same angled galley that my '77 Excella 500 had which I never liked because I use to bang my head on the overhead cabinet and it seemed to take up some of the interior space. Other than that, I don't think any other Airstream exterior can beat it for good looks.
Craig
AIR #0078
3.73 rear end
Old 03-07-2006, 09:41 PM   #9
1976 25' Caravanner
Campton , New Hampshire
Jim K is right on , need to pull the frig to change the element . You can check the outlet first without pulling the frig. It can be accessed thru the cloths closet in the bath.It's around the back by the wheel well , tight sqweeze . Also check 120v panel in bath.
ticki2 is offline   Reply With Quote
Member Titles, what do you think? Andy R Forum Admin, News and Member Account Info 17 08-18-2007 10:13 PM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 02:08 PM
Member reviews now available! Andy R Our Community 4 07-20-2002 11:34 AM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 10:15 AM
