Old 01-24-2010, 08:31 PM   #1
1964 19' Globetrotter
Waynesville , Ohio
New Member - 64 globetrotter
Hello folks! I am a new member with a 1964 Globetrotter that I am working on repairing. Slow going but making progress and having fun. I am also searching for a part for the waste line. I do not have the part that attaches a sewer line to the termination point at the rear of my trailer. A friend of mine also has a globetrotter (1962) and his has the part shown in the picture attached. Does anyone know if this is what I need or where I could get one? Thanks.
ID:	94725   Click image for larger version
64Glbttr is offline   Reply With Quote
Old 01-24-2010, 08:42 PM   #2
That part has not been available for over 40 years.
The simple fix is to replace the brass slide valve that's on the tank, with a slide valve thats been around for decades.
Then you can easily find all the attachments for it.
Thetford is the brand that gives first class performance and that Airstream has used for many years.
Communicating with a company that handles those parts, will make your task become much easier.
Anyd
Old 01-24-2010, 09:00 PM   #3
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Welcome! Always glad to see another '64! Let us know how we can help along the way, although this time I have to let others speak for the part(s) you require.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-24-2010, 09:04 PM   #4
Waynesville , Ohio
Andy: Thank you for your reply and advice! I assume that the slip valve you are referring to is what that "obsolete" piece in the photo attaches to? If so, mine is not brass but plastic and the end with the tabs that would receive a hose attachment is very close to where the grey water exits the system. I do not see where I can remove it to replace it with a newer version.
Old 01-24-2010, 09:16 PM   #5
I can better help you, or at least try, if you post a photo of what you have.
Old 01-25-2010, 06:03 AM   #6
Waynesville , Ohio
Andy: Here is the termination point of the waste line. Thanks.
Old 01-25-2010, 08:04 AM   #7
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi 64Glbttr, Looks like you need a Thetford to Valterra adapter. You can see an example here. Thetford to Valterra Adapter. Then you can use any standard sewer extension that you want. Like here. Search - Camping World. You can get the Thetford to Valterra adapter at most RV stores.
You can also find an a Thetford adapter here. http://www.inlandrv.com/catalog/prod...9fdb81fe62acd6
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-30-2010, 03:39 PM   #8
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
There is one for sale now in the Airforums classifieds by member RichardT.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
New Member - 1970 Globetrotter mstblove Member Introductions 10 06-08-2009 08:55 PM
New Globetrotter 21 Owner & Forum Member kentuvman Member Introductions 3 04-29-2008 08:43 PM
A new Member - 65 Globetrotter dldubose Member Introductions 13 01-23-2008 08:16 PM
new member - 66 Globetrotter papierski Member Introductions 8 08-19-2007 04:35 PM
Just got our first AS...'65 Globetrotter! grnthumbguy 1965 - 1969 Globetrotter 4 09-08-2005 11:22 AM
