Old 06-08-2009, 08:20 AM   #1
1970 21' Globetrotter
Coeur d' Alene , Idaho
New Member - 1970 Globetrotter
Goodmorning Everyone,
I recently purchased a 1970 21' globetrotter that I am in the process of moving into. The camper looks pretty good (hence the impulse buy), however I know it has some issues. (last time it was licensed was 1993 and I don't know if any of the systems have been used since then). I have replaced some dry rot in the floor under the berth and just inside the door. I need to get a battery and some propane tanks (yes a new regulator as well) before I can even get it checked out.
My big question today is can I pull this with my Jeep Cherokee? or Ford Ranger? Does anybody know how much it weighs? Also I need keys to the access panels, do I need to have the old locks drilled out and replaced or can I purchase keys somewhere? Thank you all so much for all the educational posts on this site. I'm gonna need a lot more help.
mstblove is offline   Reply With Quote
Old 06-08-2009, 08:26 AM   #2
SteveH's Avatar
Common Sense , Texas
The data that I have on file says your trailer weights 3330 and has a tongue weight of 380 pounds. You will have to check the tow ratings of your vehicles to find out if they will tow it comfortably, but at a minimum you will need a weight distributing hitch and a brake controller installed.
Good luck with your project and welcome to the forum.
Old 06-08-2009, 11:51 AM   #3
Airbiscuit's Avatar
1978 Argosy Minuet 6.7 Metre
Lorain County , Ohio
Send a message via AIM to Airbiscuit Send a message via Yahoo to Airbiscuit
Welcome to the forums!
Airbiscuit is offline   Reply With Quote
Old 06-08-2009, 12:04 PM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Another hello from Ohio - congratulations on your purchase.
willyd is offline   Reply With Quote
Old 06-08-2009, 01:15 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings mstblove!
Welcome to the Forums and the world of Vintage Airstream ownerhsip!
I have attached a file that contains the weights and measures for most Airstreams produced in the past 40+ years. Keep in mind that these weights do not include options, accessories, water, LP, nor personal possessions. The table shows your coach at approximately 3,400 pounds which means that your loaded (wet weight) will likely be somewhere between 4,500 and 5,000 pounds with the loaded hitch weight approaching 600 pounds.
Good luck with your Globetrotter!
Kevin
Kevin D. Allen
AIR #827
Old 06-08-2009, 03:04 PM   #6
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Hello from Kentucky and Welcome.
94Tri is offline   Reply With Quote
Old 06-08-2009, 04:34 PM   #7
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
You can get a key to the access door at the dealer. They are generic.
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 06-08-2009, 06:45 PM   #8
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Welcome -- hope to "see" your around!!
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 06-08-2009, 08:39 PM   #9
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
Welcome to the fourm!
76sovereign is offline   Reply With Quote
Old 06-08-2009, 08:41 PM   #10
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
re: keys. if there is no dealer easily available a locksmith can make you keys, should be able to do this without breaking or drilling out the locks.
TerraYacht is offline   Reply With Quote
Old 06-08-2009, 08:55 PM   #11
Ottawa , ON
Welcome to Airforum.com! Take your time, kick your shoes off and read read read!
ps: Did you mean to put "Coeur" d'Alene as your town?
New Globetrotter 21 Owner & Forum Member kentuvman Member Introductions 3 04-29-2008 08:43 PM
A new Member - 65 Globetrotter dldubose Member Introductions 13 01-23-2008 08:16 PM
I got it: 1970 Caravel k0dlc Member Introductions 19 01-20-2008 07:09 AM
new member - 66 Globetrotter papierski Member Introductions 8 08-19-2007 04:35 PM
What do I look for in a 1970-72 AS? pfay Member Introductions 5 01-16-2006 06:17 PM
