Greetings mtnman!
Welcome to the Forums!
Originally Posted by mtnman
Where do I look for model numbers, weight etc when I go see this coach Wed?
Mtnman
The vehicle data plate that lists the VIN as well as the coach's empty/dry weight and GVWR (Gross Vehicle Weight Rating) is rivited to the front panel in the vicinity of the fresh water tank fill (it is just above the fresh water fill on my '78 Minuet). The empty weight for each of the coaches can be found in the images of period sales literature for these coaches at:
http://www.airforums.com/photo...c=3178&userid=
If the coach happens to be a Minuet, most of the Minuets have a namebadge in the beltline molding (the actual placement varied by year and to an extent the model 6.0/6l7/7.3 Metre). The balance of the Argosy line usually had a painted/decal to the right of the entry door that identified the coach as an Argosy 20/Argosy22/Argosy24, etc.
Good luck with your investigation!
Kevin
