Old 12-06-2010, 04:19 PM   #1
Flushing , New York
new here and need advice
Well HELLLLLLOOOOOO there.
I am writing you from NYC area. I am looking into buying a airstream and by my screen name I am a foodie. So with that said I plan to combine the 2 together and make a mobile food truck out of an airstream. I am looking into a bambi or globetrotter model. Looking to be under 19' long. The stream will be pulled by a 1952 chevy cabover. Both will be modified and restored. They will both have airride to see eye to eye with the customer.
so I am not sure if this is the correct place to post but here is goes and note I have never owned a trailer yet an airstream. Just facinated with them:
How tall is the floor to ceiling height?
Does anyone have a floor plan of the different trailer models?
Anything I should look for in particular when buying?
Thank you all. I am off to read this forum.
Andrew
foodstream is offline   Reply With Quote
Old 12-06-2010, 04:44 PM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Checkout the following web site - www.airstream4u.de/airstream-4-u.html
Goodluck......Tim - TAC MI 14
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-06-2010, 05:03 PM   #3
Andrew
before you consider buying anything, you should first, make a floor plan as to what you wish to do.
Secondly, establish the total weight of everything you would install and/or carry in the trailer.
That then would guide you to either a single or tandem axle trailer.
Obviously the tandem will carry more weight.
Generally speaking, torsion axles have a life expectancy. They last typically 25 to maybe 30 years. However, the rubber rods in them must be exercise frequently or they deteriorate, making the axle bottom out when hitting bumps. That happens when the trailer has been parked for a few years and not moved.
Use caution who you may choose to modify the trailer, as that shop must have a working knowledge as to the type construction of an Airstream, and how you can and/or cannot modify it. If not, you will eventually pay the consequences.
Old 12-06-2010, 05:05 PM   #4
OO , OO
Send a message via Skype™ to cruiser54
The correct address is:
www.airstream4u.de
My Cruiser is altered there on European norms.
Greetings from Switzerland
Werner
cruiser54 is offline   Reply With Quote
A/C Advice CapnTom Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-17-2009 08:05 AM
New And already need some advice tn2 Argosy Motorhomes 5 01-08-2007 04:50 PM
Looking for advice anthn21 All Argosy Trailers 5 10-03-2006 06:51 AM
Advice Ga Pockets 1984-1988 Limited 1 12-22-2004 05:31 PM
Help! Need advice! Hidalgo Airstream Motorhome Forums 2 03-02-2004 01:14 PM
