Old 05-28-2018, 08:47 PM   #1
1975 29' Ambassador
Hurley , NY
New Guy
Hello Community,
I found this 1975 Ambassador . My novice eye thinks it in great shape and perfect canidate for a rebuild. Thought I'd run it through for your thoughts. I can pick it up for $2000
ID:	312316   Click image for larger version
Fincarocas is offline   Reply With Quote
Old 05-28-2018, 08:51 PM   #2
1975 29' Ambassador
Hurley , NY
A few of the interior.
ID:	312319   Click image for larger version
Old 05-28-2018, 10:06 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Might be great deal! Have you consider having it inspect?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-29-2018, 12:19 AM   #4
1980 24' Caravelle
vallejo , California
welcome, the trailer looks really nice. as has been said, get someone with the knowledge to check it out. even with the standard floor-rot i think it's worth it. kurt
ke6gkv is offline   Reply With Quote
Old 05-29-2018, 06:15 AM   #5
1970 27' Overlander
Poteau , Oklahoma
For two thousand buck it looks to be a steal even if it has some problems.They all do and looks can be deceiving. Get a good look at the bones ie: the frame in any place you can see and the floor especially around the outer edges, under windows, bath and in rear compartment. Window intact? Getting at least some electric power and water to it would be nice to check things.
I wish trailers sold that cheap around here.
It mainly boils down to is this the trailer YOU want? Only you have the answer to that and no amount of decision reinforcement should change that as you are going to spend some money getting her up and going again. Consider the 2K the down payment.
cowdiddly is offline   Reply With Quote
Old 05-29-2018, 11:52 AM   #6
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Well if you don't want it, I do! ;-)
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 05-29-2018, 05:50 PM   #7
1975 29' Ambassador
Hurley , NY
Definitely a few issues seen and unseen.
Next weekends mission is new tires ,check bearings ,break loose break and get some running lights working then maybe I can limp it home for some real inspection.
A daunting task ahead, but seems like a great starting point with minimum down payment (cowdiddly)
Thank you all for your input .
Where is the best place to start a build thread ?
Old 05-29-2018, 05:51 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome to Air Forums. Renovating these old Airstreams is a fun hobby. There is a lot of expertise in the New England area to help out if needed. These Air Forums are also very handy.
I have a 75 Overlander 27', one size smaller than this Ambassador. It was in good shape kinda when I bought it, see photos. I did the inspection myself and knew full well what I was getting into. This Ambassador you are looking at is not the most popular model. The trailers 25' or less are more popular and generally worth more.
I would suspect you could have 20k in this trailer including the purchase price to make it reliable and travel ready if you do most of the work yourself. And spending over 1000 hours on it wouldn't surprise. I can just imagine all it needs. A $2k Airstream is an expensive hobby. I don't think you can make a lot of money on this trailer, just like I don't think I can on my Overlander. I'm spending on it as I like it and intend to keep it, not fix and flip.
I hope you decide to join the vintage Airstream hobby and give this old girl a make over and back on the road.
David
Name:	1709 Colorado Springs Front (Small).JPG
ID:	312394   Click image for larger version
Name:	1709 As found gaucho 2.jpg
Name:	1709 As found bath.jpg
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Annoying new guy with annoying new guy question (major panel replacement) jme5343 Ribs, Skins & Rivets 15 05-25-2015 10:16 PM
New guy with a new trailer MerlynGraves Member Introductions 6 09-30-2006 03:38 PM
16' Bambi for tall folks / new guy checking in TinWoodsman Our Community 21 02-27-2005 04:26 AM
New Guy Questions ardenrj Tow Vehicles 11 09-30-2004 07:10 AM
Hello classic owners! New guy here. Suburban1968 Airstream Trailer Forums 5 05-04-2004 06:55 AM
