Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 10-14-2007, 11:56 AM   #15
Timbo
Profile:  1963 22' Safari
Neosho , Missouri
Originally Posted by Janet
3305 lbs
yikes.............I guess I'm gonna have to find a new tow vehicle.
Timbo is offline   Reply With Quote
Old 10-14-2007, 12:35 PM   #16
centennialman
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
Hi Tim,
The chart I have shows the dry weight at 3305 lbs with a tongue weight of 410 lbs and a length, tongue to bumper of 19.5 feet.
Hope this helps!
Steve
centennialman is offline   Reply With Quote
Old 10-14-2007, 09:56 PM   #17
Timbo
Neosho , Missouri
By the way........am I right in assuming that my trailer has brakes???
Tim
Old 10-14-2007, 10:06 PM   #18
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
It is fairly straightforward to figure out the brake system. First point will be the state of your umbilical and whether it has been updated to be compatible with modern 7-pin electrical connectors on tow vehicles. One wire is given to the brake function.
You will need a brake controller in your tow vehicle. Once you have that and your umbilical connection done right, you can place a magnetic compass near the axle on the inside of each brake assembly -- have somebody depress the brake pedal. You should see some swing of the needle from activation of the magnets.
All states require functioning breakaway brakes on any trailer over 1500-2000 pounds. New breakaway switches are widely available but most importantly you will need a functioning battery onboard to make this happen. Learn about the ancient 'Univolt' and much better voltage convertors available today. BTW -- don't test a breakaway while the umbilical is plugged into the tow vehicle -- that tends to fry brake controllers, especially the Tekonsha Prodigy.
CanoeStream is online now   Reply With Quote
Old 10-15-2007, 06:17 PM   #19
ROBERT CROSS
"The Frantic Banana"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 41
Thumbs up Just Like Our "first"
Sweet!!!!! Now I know what I have. Thanks for the link very much.
It is the camper in the 1963 Safari 2 file......exactly.
THANKS!!!!!!!!!!!
Tim
WELCOME TIM
Your "new" Stream sure brings back fond memories........
ID:	47350   Click image for larger version
Name:	STREAM'N ON RT.66.jpg
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-15-2007, 07:03 PM   #20
Timbo
Neosho , Missouri
Sweet.........wish mine was in that good of shape.
But hopefully it will be close someday. Right now I'm just hoping for a mild winter so I can keep working on it.
This forum is gonna be waaaaaaay helpful as I go along on it.
I've already got lots of ideas from it.
It's kind of cool that there was nothing original on the inside of it too. (well it was original in the fact that it looked like a tornado tore thru a lumber yard)
But with all the original stuff gone I'm not tied to a "restoration" of it. I can make it how I want without the guilt of destroying something "original".
It's just my opinion but, "original" was not comfortable.
Now I just have to figure out how to put a bed and 2 La-z-boys in it!!!!
Do they make a lightweight Barcolounger????????
Thanks for all the input guys!!!!!!!!
Tim
ps......maybe someday winterizing it won't involve plastic and duct tape!!!
Old 10-22-2007, 11:13 PM   #21
summitsmum
vancouver , Washington
hI tim-
congrats on the '63. i also have a '63 safari landyacht 22'. i just got her about a month ago and am in the process of getting her ready for the road. i would be interested in sharing thoughts and ideas with you and i have done a ton of research so if i could be of help..? good luck. summitsmum
summitsmum is offline   Reply With Quote
Old 10-23-2007, 06:45 AM   #22
Timbo
Neosho , Missouri
Sounds like yours is alot further along than mine. I have no interior in mine as of yet. This forum has been a great thing for me as well. Love that search function. Thanks for the help offer and I will take you up on it as this project goes along. Is yours all original??
Tim
Old 10-25-2007, 06:38 AM   #23
Timbo
Neosho , Missouri
........by the way, anybody got any idea where my fresh water tank and pump are supposed to be located????
Tim
Old 10-25-2007, 10:53 AM   #24
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Tim,
On my old 64GT, it was located under the front window behind the gaucho. Same for the pump..Clue is..look for your fresh water intake.
53flyingcloud is online now   Reply With Quote
Old 10-25-2007, 11:38 AM   #25
mrmossyone
mrmossyone's Avatar
Profile:  1975 Argosy 24
Collierville , Tennessee
Originally Posted by centennialma
Hi Tim,
Hope this helps!
Steve
Where is that chart? I have a 75 Argosy 24ft and would like the actual dry weight. The seller says 5000lbs and I won't to see if he is right. Thanks.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 10-25-2007, 04:39 PM   #26
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The chart ussed to be at the airstream sight, but it is no longer there. I have a copy at home and will post it later. My 75 25' Tradewind has a dry weight of 4200 pounds, but is around 5000 going down the road. I think your 5000 lb number is high for a dry weight, but close for a real weight.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-25-2007, 04:55 PM   #27
silverleeper
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Photos
Hi Tim, To see more photos of trailers like yours look here.
Lee
The more I learn the less I know!!
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
silverleeper is offline   Reply With Quote
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 08:15 PM
Just wondering how many are doing rebel beck Community Polls 9 10-05-2006 04:57 PM
We just bought.... Buttercup Generators & Solar Power 8 09-01-2006 03:30 PM
just bought #2 GO Bob Member Introductions 7 05-15-2006 11:51 AM
Just wondering? aviontt Clearcoat, Exterior Paint & Trim 11 09-14-2003 09:41 PM
