Originally Posted by yam777
Hi: Ok, and the tow plug is just for tow....How I recharge or maintain charged the battery? the 120v have a way to charge it?.....My oleander have a back door near the license plate, outside of the rear bathroom...the cable must be there or must be in the sides of the oleander? Yam
Yam,
The Overlander should have a device called a "UniVolt" in it, somewhere on the floor in a closet etc.
This device charges the on-board battery and at the smae time supplies
12V DC to the lights and fans, and perhaps a Radio or
12V TV.
It only works when it is plugged into a 12V A/C outlet. You do not need the 30A plug tomake this work, but you do if you want to run and test the A/C.
Once you are plugged into 120V, you can also use the wall plugs inside the trailer.
There are adapters available that plug into the 30A Shore power cord ( the one you still have to find), that allow youto plug it into a standard, grounded 120V household outlet. Do not use the A/C when you're using this adapter.
