Old 12-02-2011, 05:13 PM   #15
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Originally Posted by Bjleci
Here are few pics of the baby as well a a couple of happy campers
Nice! That's a big baby! Where are you? CG or is it a vacation spot? I love the huge pad! Very nice.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 12-02-2011, 05:18 PM   #16
2011 28' International
Bradford , Massachusetts
The pics are from our place in NC
Its a little hideaway my wife found online and it's where we go every chance we get
Our next getaway will be to the Carolina coast sometime in March and we're already anxious
Bjleci is offline   Reply With Quote
Old 12-02-2011, 06:30 PM   #17
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have the same model -- only it's a 2012....and while it's winterized now, I still go out back to sit in it! Did have two short weekends (it was delivered on Nov 1), and have yet to find a single issue with it. New fabric has been delivered for curtains, bedspread and accent pillows (my partner is an interior designer). Will post some interior shots when it's all finished up. I visited JC back in September to watch them build the AS....not a single 28' Intl CCD was in the assembly process. It takes 9 days to build a single trailer, and I was very impressed with what I saw and the assembly folks I talked to.
BAB is offline   Reply With Quote
Old 12-02-2011, 06:55 PM   #18
I did have one problem
Found a small water leak at the connection to the outside shower
Luckily I was able to get at it by taking the drawers out
Definitely post some pics
My wife would like to know where you got the new curtains from
Old 12-02-2011, 07:08 PM   #19
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
There is a plastic rigid, but a little flexible, extrusion that they use for cement floors that could be used on the plywood to give you the air flow and a little insulation. You could glue aluminum foil to the top of the plywood to prevent the moisture getting into the plywood. You could then glue polystyrene or extruded Blue foam insulation under the plywood. More insulation against the outer walls of the compartment and the door would also help.
Old 12-02-2011, 07:23 PM   #20
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Congratulations Bjleci, that is a beauty. Happy streaming.
F450Harley is offline   Reply With Quote
New Airstreamer : 1980 Excella II gitrokr Member Introductions 1 09-16-2011 11:36 AM
Help for a soon to be Airstreamer Chillpoints Hitches, Couplers & Balls 8 09-08-2011 06:38 PM
Airstreamer Greetings martian Member Introductions 9 05-16-2011 11:11 PM
New Airstreamer Big Project Zog Member Introductions 5 03-12-2011 11:04 AM
New Airstreamer from Florida LomedIvrit Member Introductions 14 03-09-2011 10:09 PM
