Old 12-16-2006, 03:56 PM   #15
1965 Tradewind
Clapper82's Avatar
1965 24' Tradewind
Dallas , Texas
Goucho Slides Website
My goucho is similar to your 59 goucho. The back ends of the slides on mine are attached to plywood that surrounds the water tank. I intend to make slides similiar to the ones found on this website.
The Project - Goucho Detail
Clapper82 is offline   Reply With Quote
Old 12-16-2006, 05:22 PM   #16
Images: 59
The 64 Globetrotter looks like a good solution. I can't tell from the pictures, but it looks like the base that the slides bear on is solid, not like the face frame construction used under my gaucho. Just be sure you don't have a concentrated load with no way for the load to get transmitted to the floor, or it will crack.
The slides on mine (still available, by the way) were in good condition. I did shorten them and do a few other modifications in order to squeeze the 28 gallon tank into the space where the original aluminum tank was.
New Owner "ALMOST" JLD 1974 - 1979 Sovereign 2 01-01-2007 06:57 AM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
My 66 Tradewind Site with over 100 AS links 66TradeWind Link Archive 0 02-24-2002 11:39 PM
