Old 02-25-2008, 10:51 AM   #1
1964 26' Overlander
Reno , Nevada
New 64 Overlander
Hello All! I am very excited today because my Godfather is giving me his 1964 Overlander. It has been sitting for 20 plus years in Chatsworth, Los Angeles and has never leaked! I am curious what type of connection it needs for brake hook ups though. I used to own a 63 Aristocrat and it required a special adapter. Also does anyone know what type of polish is used and how its applied? I would like to get started on that right away. Anyway, great site! I'm glad I stumbled on it. Can't wait to drive down and pick her up!!!
Sean
Croverlander is offline   Reply With Quote
Old 02-25-2008, 10:54 AM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Hi Sean, welcome and congrats on your "new" Airstream! I'd recommend using the search feature (near the top of the screen) to start looking for answers to your questions. There is a lot of good info there waiting for you. Good luck with your new project!
Mel
Mel is offline   Reply With Quote
Old 02-25-2008, 11:38 AM   #3
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Welcome Sean!!! You have come to the right place and congratulations on your new toy!
Beware though, ALL Airstreams leak at some time or another, especially if they have been sitting around for a long time.
Become familiar with the various subjects listed on this site, ask questions and enjoy!!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 02-25-2008, 01:29 PM   #4
Sean
Be sure to check out the axles.
All brands of torsion axles will have their rubber rods fail, due to lack of use.
If the torsion arms, as they go rearward are parallel to the ground or, go uphill, then the axles are done.
When the rubber rods are done, bottoming out will happen as you hit even small bumps. That in turn, causes severe pounding to the frame and shell, which in turn, causes many expensive damages.
Old 02-25-2008, 08:33 PM   #5
1964 26' Overlander
Reno , Nevada
Thanks for the warm welcome! I didn't think about the axles. I will call my down there and see if the torsion arms look like you described. I'm nervous to move it all the way back to Reno in a condition that could put anyone in danger. I did use the search tool and found all the info I needed on polishing. So Helpful!!
Help ID overlander Walt Stanton 1970 Overlander 10 10-17-2009 09:11 PM
68 Overlander Tom Kelty Member Introductions 3 09-07-2007 08:06 PM
'58 Overlander uncledaddy 1954 - 1959 Overlander 5 03-10-2005 03:26 PM
71 Overlander muskielounge Batteries, Univolts, Converters & Inverters 1 09-10-2004 08:44 PM
'76 Overlander silverhawk 1974 - 1979 Sovereign 1 05-02-2004 09:54 AM
