Old 08-15-2009, 10:02 PM   #1
2009 23' FB Flying Cloud
Bowling Green , Ohio
New 23' flying cloud owner boondocking in Ontario questions
We purchased our first camper trailer after 18 years of marriage and retiring last year in Northwest Ohio. We took our maiden trip to Maumee Bay State Park in Ohio and learned a LOT.
Now we are going to try crossing into Canada and staying at a friend's property near Stayner, Ontario. If we need to fill with water after we get up there and my friend's well is not very good, where can we fill up?
Can you fill with fresh water at gas stations? Rest areas?
Where would we dump if we needed to?
Also, can we fill the fresh water tank with a 5 gallon jug and a funnel? When we have tried this once the water just back spilled and we could not fill it.
Sorry for all of the dumb questions.
Love our new camper!
Karterlin
Karterlin is offline   Reply With Quote
Old 08-15-2009, 10:33 PM   #2
2008 23' International CCD
golden , Colorado
Water...thats pretty easy. Stop at a house and ask someone if you get desperate, but most gas stations would probably help out. A funnel and a 5 gallon should work (look for big funnel and flexible spout). Dump-stations-- most large truck stops will have (most long haul semi's have black water tanks). Most campgrounds have a dump fee that ranges from free to $5 to $20.
1cericks1 is offline   Reply With Quote
Old 08-16-2009, 06:20 AM   #3
redstart's Avatar
1998 34' Limited
ont , Ontario
you can probably both dump and fill water at the Barrie KOA, but I would call them first to make certain. I think they also fill propane.
Barrie Camping, Barrie Campground in Ontario- KOA in Barrie
redstart is offline   Reply With Quote
Old 08-16-2009, 06:29 AM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Here's a short list for Ontario of dump sites. There's lots more. A lot of tourist towns have town dump sites for the tourist buses that come to town.
Ontario | rvdumps.com
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-16-2009, 08:47 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As far as filling your fresh waster tank from bottles, we use a flexible snout funnel that is intended for use with oil. They are available at any Wal-Mart for a few bucks.
Brian
SuEllyn & Brian McCabe
Old 08-18-2009, 03:34 PM   #6
Well, I just purchased a 1 qt funnel with flexible snout and extension. We also purchased a twelve inch long clear tube with threaded attachment at one end. We tried putting the tube all the way in and filling the funnel with water from a 1 gallon jug, and it just ran back out on the ground. Are we doing it wrong?
Karla
Old 08-18-2009, 07:29 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Karterlin, on your way from Bowling Green to Stayner stop in at our place and I'll have a look at your water problem. We are right on the way and have full hookups for Airstreams. Avonton is just north of St. Marys on Perth road 130.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 08-19-2009, 10:52 AM   #8
I see that you are off the 401 a little way. If we were not on such a schedule to get up there we might do that. We usually take the 401 up to the exit that takes us thru Guelph and then on over to Airport road and up. There must be a way to fill the fresh water tank with a 5 gallon jug and we must be doing something wrong. As soon as the funnel is full, the water starts back flowing out of the tank onto the ground whether we have a short tube or a long tube.
Old 08-19-2009, 11:10 AM   #9
redstart's Avatar
1998 34' Limited
ont , Ontario
you might think this is a dumb question but are you sure you are filling the fresh water - are you filling the thing behind the little locked door? i am not familiar with the set up is for 2009s but it was just a thought!
i found this funny picture by surferstyler - how to fill your fresh water tank:
Old 08-19-2009, 11:16 AM   #10
Could you take me step by step thru using a funnel to fill? Does it matter if I test with a 1 gallon container? I got the flexible tube with hose fitting on the end and I can hook it to the bottom of the funnel. Water still over flows when we try it.
Karla
Old 08-19-2009, 11:49 AM   #11
All dumb questions are welcome. I figure we are missing some key thing that would make this very simple. I just went out and tried it (opening the little locked door, unscrewing the non pressure water cap) with the clear flexible tube screwed directly into the funnel and got the jug of water up on my hip and poured and the clear flexible tube was barely filled before the water began pouring out around it, back onto the ground.
Old 08-19-2009, 11:58 AM   #12
redstart's Avatar
1998 34' Limited
ont , Ontario
have you tried opening the drain valve on the bottom to see if the tank is already full?
i read somewhere on here but i can't find it and i could be misremembering...but someone had filled their water tank, but no water came thru the taps because the pressure valve that is located between the water pump and the water tank was stuck closed. sorry for this garbled description. but that valve keeps water from flowing back into the tank when you are hooked up to city water.
i only know this info from reading about it here so maybe someone with more knowledge will step in with better ideas.
Old 08-19-2009, 12:16 PM   #13
I think I know the problem. I just got off the phone with Airstream and they also said it should work. He directed me to look inside the trailer under the false floor in the wardrobe and check the hose thru which the water comes in. When I looked after about 8 inches of level hose thru which the fresh water enters the trailer, it rises at an incline of about 30 degrees over another bigger duct so evidently, my clear flexible hose attached to my funnel must be long enough to reach to the top of that rise or the water just flows backward when it is not under the pressure of a garden hose. I am not sure where I will find a tube long enough to do the trick, but I'll start checking.
Old 08-19-2009, 12:29 PM   #14
2007 20' Safari SE
Nashville , Tennessee
Go to Airstream in Jackson Center, and complain to the service center. The water fill hose on my 2007 Safari SE 20 was routed around the shower enclosure, and it had a rise in the hose before it reached the tank. I could not fill the tank with a garden hose and extension without keeping the flow low. The service center took out about five feet of hose and rerouted it to make a direct connection. Now I can fill the tank more quickly, and water runs out the vent hole before backing up from the fill line.
bmartinpe is offline   Reply With Quote
ontario boondocking
'59 Flying cloud Dionna 1956 - 1959 Flying Cloud 0 07-22-2009 11:04 AM
new to forum / questions about my '54 Flying Cloud Ben_KC General Repair Forum 7 07-02-2009 03:20 PM
New Flying Cloud StanandLynn Community Polls 4 06-12-2009 08:05 PM
new airstream owner - questions on boondocking JK3500 Boondocking 9 03-02-2007 01:17 AM
50-51 Flying Cloud? cloud flyer Airstream Trailer Forums 3 04-27-2005 04:23 PM
