11-05-2007, 04:09 PM
Alexander City
, Alabama
New 2007 Interstate Owner
We purchased our new Interstae in August. My wife and I are enjoying short trips. We have put over 6000 miles on it already. Live in Alabama and off to Ft Meyers Fl for Thanksgiving week. Only problem is my TV will not play a DVD when travelling (only 110 volt). Do I need a converter or am I missing something.
11-05-2007, 04:31 PM
Naples
Hi Cliff,
Welcome to the Forums! Lots of good stuff in here................
Your problem could be 3-fold, and it really depends on how Airstream did the installation.
Most motorhomes (and yours is considered one) have an interlock that will not allow the TV to operate while driving.....something about safety! Not sure if you have this set-up...but it is a possibility. Do any other 120VAC outlets work while you are driving?
Another possibility is that you do not have a power inverter, that is....one that takes the 12VDC from your batteries and inverts it into 120VAC to power things like you tele. You can solve this easily by getting the proper sized inverter (usually figure double the watts needed for your usage for sizing purposes) , connect it to your house battery bank and then plug the TV into it.
A third possibility is that you have to run your generator (assuming that you have one) in order to produce the 120VAC that you need to power your outlets and consequently, your TV.
Hops this helps. Let me know if you have any other questions.
PS: As you are headed my way, let me know if you need me to come up to Ft. Meyers and have a look at the problem if you can't get to the bottom of it. It's sort of in the neighborhood!
lewster
11-05-2007, 06:35 PM
2006 16' International CCD
Nashville
, Tennessee
I would try to make the inverter route work cause the generator is a little loud while you are running. Check with a dealer service manager at one of the bigger dealers (like Colonial in NJ) and they will advise. good luck and enjoy that Interstate
DC
11-05-2007, 07:41 PM
2005 22' Interstate
Afton
, Virginia
Inverter would be preferred
Our 2005 Interstate has the propane-fueled Onan. Indeed it is loud and probably would be annoying if I ever ran it while driving. Suggest you look up Lew and see what he can come up with.
I think a diesel genset might be a little heavy for this size of MH.
regards
11-06-2007, 07:32 AM
Colonial Airstream NJ
1961 16' Bambi
1997 19' "B" Van Airstream 190
Millstone Township
, New Jersey
Hello,
A small percentage of LCD TV's Airstream used have an AC and DC adapter, this would depend on which brand they were using at the time your Interstate was built. If the manufacturer of the TV does not include or sell the DC adapter, a small inverter can be purchased from radio shack and plugged into the DC power port near the entertainment center. Once plugged in, you can plug you TV's AC adapter into it.
It is kind of silly that an LCD TV is DC native and they convert it to AC and don't sell or provide the DC adapter with the TV. This means you are going from DC to AC to DC again.
Patrick Botticelli - Colonial Airstream 595 State Hwy 33 Millstone Township, NJ 08535 - 1-800-265-9019 www.colonialairstream.com
11-06-2007, 08:06 AM
Tonka Bay
My LCD flat screen TV (Samsung) and DVD (Concept) in my Sprinter B camper van are 12V powered so will play while driving. I checked the Airstream specs and they do not say what the TV/DVD is specifically. Check your information to see if yours is supposed to run under 12V. If it is then there is some other problem.
Also, it is not advisable to run an LPG generator while driving. The LPG should be turned off when underway.
The only things on my B that operate on 110V are the microwave, electric coffee pot, 110V plug in outlets and the 110V option of the 110/12/LPG three way fridge.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
11-06-2007, 03:05 PM
Naples
Davydd,
Could you explain your reasons for turning off the LP while under way? I know of many, many RV'ers who run their LP gen's, refrigerators, water heaters and furnaces while under way (motor homes). I run my fridge on LP while towing.
I know some think there is an inherent safety problem in doing so, but I am unconvinced.......
Thanks so much!
lewster
11-06-2007, 03:14 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Originally Posted by lewster
Davydd,
Thanks so much!
Glad to see Lew support my opinion. The only time I had my propane off while towing was going through a tunnel in the Rockies, and they (officers) shut it off themselves to be certain.
Vaughan
11-07-2007, 12:34 PM
Tonka Bay
Four reasons.
One is simply safety whether you buy into that or not.
Second just cited by vswingfield, it is illegal to go through a tunnel and other posted areas with propane on and there area lot more tunnels than the Rocky Mountains that do not have officers around to shut you off.
The third is insurance. You'll have fun explaining damage from propane being on underway. I doubt you will collect.
Four. The manufacturer's printed manual says not to probably for all of the above and their own warranty issues.
But getting back to the original question about the TV not playing while underway. It would be ridiculous to run a propane generator underway just to power a TV/DVD in my opinion especially when such options are readily available in 12V. I have no interconnect preventing watching my TV. It is in the back of the van and only viewable by someone sitting in the back, not the driver. As I mentioned before, Airstream does no specifically say what they provide in the TV/DVD but I thought most converters provided 12V power.
Davydd
11-09-2007, 12:22 PM
Tonka Bay
A fifth reason occurred to me. In a motorhome such as the Interstate you are sitting in the box as you go down the road where the propane is actively engaged. Maybe those with trailers don't have those concerns since trailers are generally unoccupied when moving. Does that make a difference in the attitude about using propane while moving?
Davydd
11-09-2007, 05:45 PM
Naples
Nope,
I full-timed in a 40' Monaco Dynasty diesel MoHo for 5 years and the only time I turned off the LP was going thru a tunnel or fueling. The fridge ran on LP the entire time I was on the road, as did the range and furnace. Most of my MoHo buddies did the same thing.
If the OEMs were that concerned about using the LP while running or there were serious safety issues, they would have installed a solenoid operated gas valve at the LP tank that would only allow LP to flow when the engine was off......similar to the locked circuits you find on MoHos that will not allow the front TV on while the ignition is on.
Plus, when you full-time, what are you supposed to do with your fridge and all of the food in it? No modern MoHo has a 3-way fridge anymore that runs on 12VDC, plus, the huge amp draw is a great drain on the batteries. That leaves running on 120VAC from the generator, or LP while running. While I would run the gen in very hot climates to power up the roof A/Cs to keep the coach cool, I never did it to run the fridge.
I do know folks that are so worried about LP that they don't even have any tanks on their MoHos and opted for all-electric coaches. They have huge battery banks and run the gen almost constantly to power the 120VAC-only fridge and electric range and oven, or the use their 3000 watt inverters and give their batteries a regular workout, requiring them to run the gen anyway after a while to re-charge the batteries.
lewster
11-09-2007, 06:51 PM
2005 22' Interstate
Afton
, Virginia
LP or not LP, that is the question
Sorry, Will.
Believe it or not, my 2005 Interstate has a full-time Propane Leak detector built-in. I bless it each time I fill on propane, for it has a piercing whistle.
Unless Airstream deleted this safety feature in the 2007 IS, this should alleviate some of the anxiety about leaving the Propane on while driving.
Personally, I don't give it a thought until I get to a fuel plaza where the diesel and gasoline are in the same dispenser. Then I shut the LP down and relight after driving off the pad. And I do obey the tunnel restrictions.
regards
11-09-2007, 07:12 PM
West of Fort Worth
This subject will never be settled.
You can turn your fridge off in the AM and it will be cold when you arrive. I do it all the time.
With all of the vibration and possible movement of gas lines while travelling, I elect to turn my gas off while moving. If you are going to have a problem, during transit will be the time. The possibilities for a gas system failure are many, including fittings loosening and hoses or tubing abraiding or cutting on a sharp edge.
When I arrive at my destination I turn it back on, pretty simple.
Because you've never had a problem is no reason that you never will.
My viewpoint.
Dave
11-09-2007, 07:40 PM
2005 22' Interstate
Afton
, Virginia
Dave, I agree that this subject will be worse than the ole "404" thread.
Probably have to drive a stake through its heart to kill it, like Dracula.
But, my fridge barely keeps things cold, UNTIL I want to keep the lettuce crispy, then it freezes it solid. I'm not thrilled with it, but that's another story.
I know somebody must have statistics on things like this, but I never gave it a thought until now.
How many RV's have had a propane-based explosion or fire caused by a leak underway? I've not been made aware of any in the 10 years that I've been back in the States, but I could have missed one or two.
I think LP gas is dangerous, sure, but so is gasoline.
No sarcasm intended.
regards
11-09-2007, 07:47 PM
West of Fort Worth
I totally understand.
The cure (turning it off) is just too simple for me to risk.
Managing risk is a part of my business.
It's a personal decision for each of us.
11-10-2007, 11:28 AM
Tonka Bay
Lew,
The standard setup for almost all B motorhome manufacturers including the Interstate is to have the three-way AC/DC/LPG refrigerator so you can run 12VDC on the road, LPG when boondocking, and 110VAC when plugged into shore power with a 30 amp service. The one coach battery is adequate for that. Air-conditioning is satisfactory from the van's normal engine cab air conditioner. The rooftop electric air conditioner is generally only used in the campground. Everything on my B Sprinter runs on 12VDC except the rooftop air-conditioner, the microwave, the 110V std outlets, and the Black & Decker coffee pot. The TV/DVD, all lights, propane furnace fan, LPG generator starter, CO2 detector, LPG detector, control panel lights, Fantastik fan, water pump, and ignition for LPG water heater all run off 12VDC via the coach battery and converter keeping up the battery charge when plugged into shore power or when the generator is running. Since the fridge is three-way there should be no reason to run it on LPG while on the road or LPG when plugged into shore power. I will use it on LPG when boondocking without shore power or during a lengthy stop of an hour or more during the day on the road.
The Interstate Sprinter B van is pretty efficient. The B van manufacturers tune their setups to generally get by on one coach battery mainly because there is little room for more otherwise. I get by with one AGM 95AH deep cycle battery that sits under the front passenger seat. Our spare tire is under the van. Some manufacturers mount the spare on the back and use the space under the floor for a couple of batteries. I don't know of anyone with a setup with more other than some do it yourselfers with three. Inverters to run 110VAC off batteries thus are rare in B vans other than some done by DIYers.
The Interstate is capable of traveling with two people maximum as it only sleeps two. Rarely would it be used for full-timing and it would be used mostly for touring and driving every day to charge batteries without the generator even when staying at campgrounds multiple days. There are some people who do full-time in Bs or travel over a long time but generally they seem to be single users and when a couple they seem to travel a lot and not stay in one place very long. I did meet one couple that were camp host at Bear Head State Park near Ely, MN for a full month. That was a rare surprise. They were itching to get moving at the end of the month. Bs are pretty confining just to live in.
Davydd
11-10-2007, 03:01 PM
Alexander City
, Alabama
Just a follow up - A trip to Radio Shack this morning fixed the problem with a small converter. Thank you all for your help.
11-10-2007, 05:36 PM
Naples
Lew,
Thanks for the heads-up on the 3-ways in the B vans. I run a Sprinter for my service van with a 150 amp alternator, but I would suspect that the chasis used for the conversions have the 200 amp version. Lots of juice out of that unit.
lewster
11-10-2007, 06:35 PM
2005 22' Interstate
Afton
, Virginia
Not Quite
Lew, for sure, my 2005 Interstate has the Dometic equipped for 120 VAC and LP. There is no 12 volt heater on the stack. I can't speak for the 2004, 2006, or 2007 models, but the one I bought is as I stated.
OK, now that we've rode this hobbyhorse far away from the original idea, and now that the problem has been solved, how's about we grab another one from the rack?
regards
