Old 04-10-2008, 07:55 AM   #1
Unhappy Nelson
Am restoring the old camper: Work in progress -
sustem by system inspection and repair/replace as necessary ...
- the seal on the old fridge is/has been a real frustration -
the factory sent me the (they say) exact type replacement gaskets for the Dometic model - and yep they (2) are different from what had previously been installed - and getting everthing to fit - (beginning to suspect the old installed attaching system is for a diferent type refrigerator gasket?)
Windows sealed // screens replaced - over head vents re-worked and re rivited -
---------Water system next - ----
Hot and cold water plumbing (lines) next (this weekend 4-10-08):
followed by
hot water heater - remove clean // test and repair/replace/ reinstall/
(any suggestions will be welcome ?)
nelson.groom is offline   Reply With Quote
Old 04-10-2008, 01:15 PM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Hi Nelson - welcome to the forums! You've got a lengthy to-do list, but there are many here who have survived similar experiences. Check out the search feature at the top of the screen and you should be able to find some good advice on your repairs. Let us know how things shape up, and good luck!
Mel
Mel is offline   Reply With Quote
