Old 10-05-2007, 09:06 AM   #1
arthur carle's Avatar
1974 Argosy 26
1989 32' Land Yacht
st. clairsville , Ohio
need help with a 1974 26' argosy
I bought a 1974 26' argosy this spring to give to my son as a hunting camp on his 50 acres of woods. It was previously also used as a hunting camp by former owners. I am finally getting around to fixing it up. My former experience is making a 1950 spartan 33' usable in the woods 40 years ago. I am mechanical. First of all i need a owners man. or reprint or a good copy or download. This one has rear bath,twin beds mid and front sofa with folding table on L. It is not too bad tho. I went over wiring, then hooked up battery, tried lights-ok, then plugged in 110 and flipped 2 cb's all 110 plugs work. questions= the front steps were down when bought but for moving i stowed, now they won't come out. What is procedure to get out= the knob seems frozen, but i also tried the day i put it up when i got home. at L. rear there is a clear jeweled eye near hose port. what is this for? No brighter with power on. on wall half up above kitchen sink there is a rocker light switch, what is it for? I plugged in fridge in behind the removeable panel outside and followed inst. inside fridge lower bottom panel to power up nothing. is elect power 110 or 12 volt? dometic cc gg model says 110 made in sweden. there is a vent fan in the top vent abeam sink (doesn't work) is this original? 12 or 110? stove vent going outside has vent flapper control, flapper works, but not fan,
arthur carle is offline   Reply With Quote
Old 10-05-2007, 09:13 AM   #2
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Try using some oil on the mechanism for the steps, pressing down on the lever, the steps should drop down on their own.
The little jewel lens on the outside is thewarning lamp for an improperly wired outlet. If it's off, the AC power you're connect to is OK. If it's on, unplug REAL fast so you don't hurt the trailer power converter and battery.
The switch by the sink is for the water pump. Not needed if your hooked to city water, but necessary for using the fresh water holding tank.
The fridge takes a long time to get cold, especially on 110 power. Mine works much better on LP gas.
Mine doesn't have that vent on the roof because it was retro fitted with an AC unit.
Take the filter off the range hood and use a volt meter to check if power is going to the fan, should be 12 volts. It may be a dirty switch.
I've only had mine for a week, so I'm sure someone else will chime in...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-05-2007, 10:13 AM   #3
1974 Argosy 26
1989 32' Land Yacht
need help
bob thanks for reply you helped a lot would you share your phone no. mine is 740695XXXX thanks i have more questions. arthur
Old 10-05-2007, 11:37 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Just be careful if this has the original furnace. See http://www.airforums.com/forums/f427...call-2889.html. The exhaust manifold deteriorates with age and leaks into the cabin. Don't wanna wake up dead.
5 meter Langford Nahanni
Old 10-05-2007, 12:57 PM   #5
bobfowler's Avatar
1972 Argosy 20
Images: 14
bob thanks for reply you helped a lot would you share your phone no. mine is 7406956310 thanks i have more questions. arthur
I sent you a PM...
Bob Fowler
TAC - NJ-007
1973 Argosy 26' Axles Sundance Axles 18 04-14-2007 07:45 AM
73 Argosy 26' to be parted out. balrgn All Argosy Trailers 13 03-12-2006 01:01 PM
1975 Argosy 26' robandzoe All Argosy Trailers 3 03-04-2005 04:48 AM
Our 1975 26' Argosy..cleaning it up Happycampers All Argosy Trailers 5 04-11-2004 12:46 PM
