Old 11-09-2015, 03:59 PM   #1
1977 27' Overlander
1976 Argosy 26
Baltimore , Maryland
Need help from experienced Airstreamer in Baltimore area
Hi,
I recently purchased a 1977 27' Airstream Overlander.
I am looking to meet up with someone who can walk through the Airstream and show me how to operate the various functions.
So far, I have good batteries and the 12 volt system is working.
I have an electric cord connected and have electrical power though I am just plugged in to a standard outlet, not a 30 amp outlet.
I have gas. Both the stove and furnace are operating.
I haven't tested the water systems because I am not sure howe to properly winterize the system when I am finished testing.
In short, is there anybody in the area (21286 Towson) that could come by and help familiarize me with the operations and need to knows before I undertake any travel.
Thanks in advance!
John
jthk is offline   Reply With Quote
Old 11-09-2015, 04:23 PM   #2
mandolindave's Avatar
Congrats on your new trailer...
You are off to a good start. You will learn a lot on this forum.
But you have two problems.
#1 Winter will make it hard to test the fridge, and the plumbing, and uncomfortably cold to do much of anything.
#2 You might not know what you don't know.
My advice would be to start at the start
#1 Tires, brakes, and bearings
#2 Check the pipes and coils in the rear of the fridge for a goldfish green
ooze …it's dangerous
#3 you said your battery was good, but the correct way to check it is to charge it for a few days and unplug the power from the house, let it sit for a day or so and test the voltage of the battery, if it reads less than 12.6 volts, start saving for a new batt.
mandolindave is offline   Reply With Quote
Old 11-09-2015, 05:38 PM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
From last comment: "if it reads less than 12.6 volts, start saving for a new batt."
12.6 volts is at 50% of battery capacity! This was as low as I let my batteries get when I used wet cell batteries.
If a freshly charged battery only came up to 12.6 after a day - you need new batteries!
Silver Hawk is offline   Reply With Quote
New to Airstreams need help from experienced Airstream renovators/collectors megank Airstream Trailer Forums 5 04-14-2015 09:55 PM
Looking for experienced woodworker in DFW area txlogic Cabinets, Counter Tops & Furnishings 1 12-02-2014 10:29 AM
Help wanted. Experienced only need apply sarasafari General Repair Forum 0 06-12-2013 03:07 PM
need TV shipped from montana to baltimore remcolent Shipping & Export/Import 2 05-02-2008 06:02 PM
New member in Baltimore area jfcoll Member Introductions 4 06-13-2007 09:11 PM
