Old 05-19-2014, 07:34 AM   #1
1995 30' Excella
New Denmark , New Brunswick
Need help
Hi, I wish to post pictures of our airstream renovations (before and after). when searching on how to do it, it refers me to the user control panel and says i need to use the pictures and albums link but i see it nowhere. Can someone help me. Tks
peach is offline   Reply With Quote
Old 05-19-2014, 08:05 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you open a new tread window or a reply window you will see a tool bar across the top. About center on that tool bar you will see a paper clip. If your pictures are on your computer click on the paper clip. That open a window that will allow you to browse through your computer and select a picture. Once you find the picture you want click on it and then click Open. That will post that picture to your reply. If you want a second picture browse again.
2004 Excursion 4x4
Old 05-19-2014, 10:12 AM   #3
1995 30' Excella
Making an album
Can i picks more then a pictures at the same time ?
Old 05-19-2014, 10:14 AM   #4
HowieE's Avatar
Images: 12
Yes
2004 Excursion 4x4
Need help with pedestal…..help! FromDad Sprinter and B-van Forum 4 04-02-2014 11:05 PM
Help! Need help with parts - '69 Sovereign kimcup General Repair Forum 6 06-08-2009 09:54 PM
Need work? We need help! (Seattle area) 60traveler General Repair Forum 3 04-01-2009 08:03 PM
Need to replace airconditioning unit need help... retrocowgirl Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-16-2006 09:15 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
