Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 10-24-2007, 09:31 PM   #1
JoeF
Profile:  1999 19' Bambi
Altamonte , Florida
Need advise removing fuzzy ceiling carpet glue
Our 19 foot 99' Bambi has the fuzzy carpet on the interior walls. We would like to take it off (because of my wife's allergies). We've already replaced the carpet with wood graim linoleum which turned out beautifully. Has anyone taken on this project and been successful with removing the glue underneath and showing the aluminum or applied vinyl or another material?
JoeF is offline   Reply With Quote
Old 10-24-2007, 09:46 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us.
I haven't tried removing the fabric wall covering, but I might try to remove a small section in an area that is not easily seen, and use solvents to disolve the glue. I would start with lighter fluid or naptha.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 10-24-2007, 09:57 PM   #3
JoeF
Altamonte , Florida
Thank you Brian for the suggestion. I've gone to Homedepot and they suggested paint thinner, Lacquer thinner, turpentine, truegreen and the glue has laughed at all of them. I even called Airstream and they said they havent found anything that removes the glue.
Old 10-24-2007, 10:06 PM   #4
moosetags
moosetags's Avatar
Try the lighter fluid (naptha) first. Let it sit for a minute on the glue. If that doesn't work, try, Goof Off. It's stronger that the Naptha. The stuff that you mention is for paint, and wouldn't have much affect on glue.
Brian
Old 10-24-2007, 10:18 PM   #5
JoeF
Altamonte , Florida
I'll let you know how it works. I'll get some this weeked (Both)
Thanks a million!
Old 10-24-2007, 10:31 PM   #6
2airishuman
2airishuman's Avatar
Profile:
hi joeF
the 3m adhesive used to attach the mouse fur ISN'T gonna come off easily...
it at all.
3m does make an adhesive remover which might work, but i doubt it.
none of these other water, oil or solvent based products will loosen it....
a heat gun, and a scraper and elbow grease, a LOT of elbow grease, but the results will NOT be pretty.
not to change your efforts (many simply don't like the mouse fur) but the fur should have NO effect on allergy sufferers...
it's a polyester fiber and a non allergen, called ozite rib fabric.
Hytex - Ozite Rib Acoustical Fabrics
details in the attached pdf...
yes dust or pollen or animal dander could get on it but the fabric itself is inert.
it can be cleaned with solvents, water or dilute surfactants. wet, blot, blot, blot dry.
vacuuming will pull black alum dust to the surface (it is NOT mold) and badly discolor.
the carpet was a piece of cake to remove/replace.
this stuff is really attached and the skin under it ISN't gonna look like the shinny skinned interiors, no matter what.
it is a major effort to remove, like trying to skin a bear...
a LIVING bear....
cheers
2air'
all of these products are just gonna make a nasty mess IN the fabric (i guess it's a chance to practice their cleaning tips)...
http://www.hytex.com/pdf/ozite_spec.pdf
i've got a link to the actual adhesive somewhere, this one is the fabric.
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-24-2007, 10:36 PM   #7
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Possibilities...
On the factory tour, that glue is FOUL stuff....
I'm not sure if this will be any help, but many glues are incompatible with vegetable or mineral oils.
Try putting some olive oil or other salad oil on a small spot of the glue and leaving it for 5 to 10 minutes. If it's going to work, the glue should soften and sort of ball up as you push it around. Use the edge of a credit card or an acrylic razor blade to nudge it off the aluminum. If the veggie oil doesn't work, try mineral oil or WD-40. Again let it sit for about 5 to 10 minutes before you test it.
Good luck. Unfortunately the aluminum underneath might not look as nice as the CCD or SE Safaris - they use slightly damaged pieces on the ones they know will be covered by "the rag".
Paula
Today is a gift. That's why they call it "the present"
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
