Old 09-29-2006, 02:42 PM   #1
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Much information needed
I just bought a 72 31ft sovereign the previous owner is pretty old and can't remember how anything works. is there some place i can get information on this unit. i do have some things i really would like to know about now.
1. is there a power invertor on this unit
2. how do you get the stuff that looks like peeled wax out of windows on top of trailer.
3. does the battery charge automatically when pluged into 110 power
I have a lot more questions but will save for later.
thanks, richard
gutsgolf is offline   Reply With Quote
Old 09-29-2006, 03:08 PM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Hey richard nice all the answers are found by using the search button, give it a whirl enough info to keep you reading for hours. Have fun camping!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 09-29-2006, 03:08 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
welcome to the forums!
Since your 'new" trailer is 34 years old, no one but the PO knows any of these answers...any number of things could have been changed over the years. But as configured by the factory:
it had a "converter", which is different from an "inverter"...and it will charge your battery when its plugged in...IF its working properly. It'll also over-charge it, so beware of that.
There is a "search" feature on the forum. try searching for terms like "univolt" (the brand name of the converters installed by airstream), "vista view windows", for threads about your window problem. you'll find hours and hours of reading pleasure...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-29-2006, 03:16 PM   #4
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
thanks, richard
Richard, Welcome to the forum. You can get an owners manual and a service manual from what's her name in Ohio, someone fill in the blanks for me on this please....
Ok, about your questions....
1.(and 3.) Your trailer came with a convertor called a Univolt. It is powered on when you plug into shore power. If it is functioning you should here it hummmmm. It also charges the battery and often will over charge the battery. These were good units at the time, but many members have replaced these with the better units that are available today.
2. Those are your vista view windows, mine look like crap also. Take a look at this proceedure by balrgn on how to repair those. http://www.balrgn.com/Airstream/Vist...Vista_View.htm
Try the search feature located on the top of the screen to get as much information as you can. If you search on Vista View windows or univolt you will have a lifetime of information.
Richard
Old 09-29-2006, 03:50 PM   #5
1976 25' Caravanner
Campton , New Hampshire
Be aware there are two versions of "Vista-view" windows . One has two panes of glass while the other has one glass pane and one plastic pane . They require two different methods of repair . Both methods are on here some where , but first you need to determine which type you have. Good luck
ticki2 is offline   Reply With Quote
Old 09-29-2006, 04:04 PM   #6
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Richard-
1. An "inverter" converts 12v-DC to 120v-AC. The trailers of this era did not have them. It may have been an addition by the prior owner.
2. The Univolt (converter) on my rear bath '72 is located in the rear curbside closet. You remove the false floor first, the there's an access panel on the right side wall of the closet. Open that up and you should see the Univolt. The part that faces out is the fuse panel. The unit is about the size of a tall shoebox and sits with it's long part tucked in under the bathtub.
3. The Univolt should charge your battery as well as provide 12v to your trailer when plugged in.
Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 09-29-2006, 06:09 PM   #7
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Richard,
Welcome to the forums, and welcome to another old 31-footer. Here's my major contribution so far.
Where to Start with a 70's Trailer
http://www.airforums.com/forum...tml#post272422
Have fun!
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-29-2006, 06:29 PM   #8
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
31 footer
I have the same unit rear bath and mid twins in mine. The unilvolt is in the rear right side storage area in mine tucked toward the under side of the bath tub. It should charge when plugged into the wall or your tow vehicle if wired for it (tow vehicle)
mustang is offline   Reply With Quote
Old 09-29-2006, 07:08 PM   #9
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hello gutsgolf ,If you want a owners manual for your trailer call
Helen Davis Secretarial Service
937-492-8885or PO BOX 484
Sidney Ohio 45365
$30.00 for owners manual or $60.00 for shop manual...
bobchevy89 is offline   Reply With Quote
Old 09-30-2006, 10:25 AM   #10
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
WOW, I am very impressed with this community and looking forward to meeting and helping if possible. Thank you very much for you help hope to do the same for you soon.
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 02:43 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 07:08 AM
Information needed on Passport America John On The Road... 8 03-07-2004 07:22 PM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 05:03 PM
Calendar Updaters Needed! Andy R Our Community 0 06-16-2002 02:05 AM
