Old 10-01-2006, 05:56 PM   #1
Cabot , Vermont
Mod Airstream
This is our 74 Sovereign, and in addition to solving all the typical problems with an old, under-maintained rig (leaks, mold, etc) it was completely remodeled inside. New floor and subfloor, furniture/cabinets, paint, and stainless are among the list of additions we threw in. Please let me know what you think of this unit, as it is my new home!
ID:	26475   Click image for larger version
ID:	26481   Click image for larger version
ID:	26483   Click image for larger version
elliottkatz is offline   Reply With Quote
Old 10-01-2006, 06:52 PM   #2
summerkid's Avatar
1956 16' Bubble
Rose Lodge , Oregon
Love it!
Are you on the road? Where would one encounter such a gorgeous, unique trailer in person so as to thoroughly inspect your workmanship?
Of course I'm an elitist. Look around you.
summerkid is offline   Reply With Quote
Old 10-01-2006, 06:55 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Nice job, I like the mix of vintage and new!
'77 Sovereign Intl 31' CB
Old 10-01-2006, 08:47 PM   #4
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Love it.. so clean and unclutered. lots of room.The only thing I would do is put a small fold down table where the laptop is..
bobchevy89 is offline   Reply With Quote
Old 10-01-2006, 09:02 PM   #5
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Nice!
I would also put a table and comfy chair where the laptop is! Then I would have comfy cushions for my back on the front couch...
I like the clean and unstated look! It would probably take me 5 minutes to fill up your nice trailer and get it cluttered. As much as I try the simple approach, I seem to be like pig-pen in the comic strip, but my "cloud" is bunches of stuff! At least I don't collect rocks like Lucy in the Long, Long Trailer!
Hope to see you on the road!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 10-01-2006, 09:04 PM   #6
claybags's Avatar
2007 25' Safari FB SE
rio rico , Arizona
WOW!!!
cheers, Jeff
claybags is offline   Reply With Quote
Old 10-01-2006, 10:45 PM   #7
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Looks great!
Is that stainless steel on all the cabinets and doors? Looks fantastic!
Did you paint the inside also?
Marc
Old 10-02-2006, 08:18 AM   #8
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
elliottkatz, welcome to the forums! Your Sovereign is just beautiful - great work. What a wonderful place to call home! I'd love to see some "before" pictures - always makes an impact when you compare before & after.
Mel
Mel is offline   Reply With Quote
Old 10-02-2006, 08:21 AM   #9
newbie
audiobox's Avatar
Fort Wayne , Indiana
Tres Cool!
My first reaction is, "wow!" Then, I want to know, "how?"
Did you use a satin finish paint inside, or a matte finish? What type of paint? Did you pull the tambor doors and spray? Any slide problems after you re-installed? Did you use the same type of paint on the inside of the main door? Did you just clean and Flitz the existing vinyl for prep? Did you paint the existing closet doors or replace them? What did you spray/roller/brush? Is the orange accent color laminate or paint? That doesn't look like a Zip Dee awning, did you make your own? Are you planning on window treatment? Did you contract any of the work out? Did you change or re-work any of the infrastructure; electrical, plumbing, frame, axel, etc? Did you scoop it out, install the floor and then, re-build the interior? Any plans for solar? I'll stop here, but you realize this is, "How'd they do that?" central.
Kudos to your design sense!
Craig
audiobox is offline   Reply With Quote
Old 10-03-2006, 09:53 AM   #10
Cabot , Vermont
Hi Everybody,
Thanks for your replies! All of your suggestions are certainly on the to-do list- I need a table and at least one other place to plant my rear in that main living space.
As far as the technical how-we-didits, all the work I did along with my sister, and her boyfriend. It took about two and a half months to bring it to its current state. When we purchased the vessel it had been left sitting under leaking trees for a year and was pretty gross inside. After I pulled the molding carpet and tore into the rotten floor I found numerous ant farms living in the plywood, and of course a small snake that we imported from NY to eat the ants... But otherwise, much of the AS was in decent shape. The skin is in very good condition and all the appliances seem to work very well. The floor was only rotten in places, and I did not have the time to do full on ply replacements, so I just did the front space and the rear bedroom space and left the hall original. I chose to leave the plumbing, axel and electrical stuff alone for the time being, but could see some of it being addressed in the future.
We primed the interior with some run of the mill bacteria killing primer and then painted the interior with a behr variety satin latex from home depot (Fencepost is the name). Nothing special but so far so good. The only problem I've had with the latex is on the vinyl wood veneers. I did not prep the vinyl as much as I should have (should have done extensive sanding. I don't know what Flitzing is) so the paint can be scaped off fairly easily. Most of the painting was done by 3inch rollers but we did hit difficult areas (hinges, latches etc) with white spray paint. That worked well enough. The orange is also a satin latex.
Now for my questions:
That awning is a problem actually. I need a new spring for one end and have no idea if there are any available. Its a Carefree awning and seems to be totally obsolete. Any ideas?
Also, I'm still getting some leaks after having spent countless hours resealing the exterior. The leaks are coming from above, and I removed and resealed all the vista views and all the gutters. I also resealed the roof vents but wonder if anybody has ever had leaks come into the vent openings and trickle down the inside of the walls?
PS: I have only one picture of the old interior on my computer. But I'll find more.
Old 10-03-2006, 10:25 AM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Check your sewer vent gaskets! they are a likely culprit
http://www.airforums.com/forum...highlight=vent
I don't see an antenna in your pic, but if there was one, and the base is still in place, that's probably leaking, too.
and yeah, any water that gets in will trickle down the walls. It can even go up hill from the sewer vents. the insulation gets soaked, and can "wick" the water almost anywhere.
also check your fridge vent. and around the a/c...Basically, any penetration of the skin up there is a possible culprit.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-03-2006, 11:27 AM   #12
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Like everyone else, I'm impressed! Great job.
It looks like you are in Vermont? You may want to search for some recent posts regarding winter living in an A/S, just to give you some things to consider. From what I've been reading it looks like it can be done, but there are some major considerations. Hope all tha best for you in your A/S, looks great.
Dave
Fyrzowt is offline   Reply With Quote
Old 10-03-2006, 12:26 PM   #13
newbie
audiobox's Avatar
Thanks for the insight into some of your refurb approaches, Elliot. I'm going to be taking our 34' Excella in a similar direction.
Excuse me for refering to "Flitz," which is a line of metal & fiberglass cleaner/polishes. What I thought I was remembering was, "B-I-N Primer" made by Zinsser. It's shellac & alcohol based and is used to prime glossy, vinyl type surfaces like the Airstream interior.
Thanks for sharing!
Craig
Old 10-03-2006, 04:03 PM   #14
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
You have a beautiful trailer. Nice work
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 07:35 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
