Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 05-16-2008, 10:10 AM   #1
artie5208h
Profile:  fuquay varina , North Carolina
mirrors
i have a 1997 land yacht, the other day i went into the unit to get a tool.
found that a mirror had fallen off the med chest door over the commode and shattred it as held on by double sidded tape. e mailed air stream to see if there was any rretrofit to secure the otther mirrors they suggest mirror clips wouldnt work as mirrors total cover the door they said they still use tape to secure the mirrors. if any one else has had this problem and has a fix.
would love to hear from you thanks
artie5208h is offline   Reply With Quote
Old 05-16-2008, 12:28 PM   #2
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I would try to glue a piece of the old mirror to the same type backing using PL400 construction glue. I suggest using a sample just to make sure the PL will bond to the mirror back. Unlike contact cement the PL will give you some time to position the glass. If the PL works on the sample take the door off and position your new mirror while the door is laying flat and let the PL set up overnight then remount the door.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 05-16-2008, 01:26 PM   #3
Isadora
Profile:  1976 Argosy 24
Joplin , Missouri
Some glues will dissolve the silvering on a mirror, be sure to test anything on a scrap before you try it for real.
Jim and Sandy
"For still there are so many things
That I have never seen.
In every woods, in every spring,
There is a different green."
Bilbo Baggins 'The Hobbit'
Isadora is online now   Reply With Quote
Old 05-16-2008, 05:15 PM   #4
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
Double-sided foam tape will hold mirrors very well if you use enough. Relative to the cost of the mirror, the tape is cheap, so use numerous strips (say 2-3 times as much as Airstream used). The foam tape has many advantages including handling differential expansion between the mirror and its substrate and adjusting to irregularities in the substrate.
Tim A. is offline   Reply With Quote
Tow Mirrors nazz300 Community Polls 42 05-10-2008 10:56 PM
Tow-N-See Mirrors Silvercamper Towing, Tow Vehicles & Hitches 43 01-16-2007 08:25 PM
outside mirrors tandemfish General Motorhome Topics 8 10-27-2004 09:03 AM
mirrors? tinman7 Towing, Tow Vehicles & Hitches 1 03-15-2004 08:54 PM
side mirrors ALANSD Airstream Motorhome Forums 5 04-20-2002 07:38 PM
