Old 10-13-2009, 12:49 AM   #1
wed
2001 31' Excella
Salt Lake City , Utah
Unhappy mice and chipmunk problems
We are the third owners of a 2001, 31' Excella. Our efforts to find out where these little critters are getting is still eluding us. We are really hoping someone out there could give us some clues. Thank you in advance
wed is offline   Reply With Quote
Old 10-13-2009, 01:23 AM   #2
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
A couple spots that I found on my trailer were
1) Any of the external compartments
2) Check your belly pan for any holes
3) Frame rail?? I don't know how the new A/S's are designed but someone lead me on to this one. They come in through the opening's in the frame rail, then they pretty much have full access to everything.
4) Roof Vents
Granted my A/S is 30 years older than your's, i'm sure that some of the spots are the same, regardless of the year. Take a look at my blog for some "interesting findings" that I had.
Hope you get rid of the little buggers. If all else fails, get a cat (or dog) My dog/cats got rid of all the rodents in and around my trailer
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 10-13-2009, 05:23 AM   #3
Kevin245's Avatar
I hate these little %$*&!!
Mice can get in through very small openings, as in smaller than the diameter of a Woman's pinky finger. In addition to what Brian states, I would focus on the areas around the:
Steps
LPG line penetrations
Rear bumper storage
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 10-13-2009, 06:00 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yup, the barn cat worked for me. I sealed all I could, but they still got in and ate the poison I'd placed around the AS. Then the cat caught on. End of problem.
Old 10-15-2009, 02:57 PM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I won't use a trap...but some real sticky stuff is called Gorilla Tape you can get from Walmart. Construct about a eight by eight inch square of it ---lay it stickyside up in a warm dark area and put a dab of peanut butter in the center.. It's a interesting way to go for the critter (well I figure he wouldn't think so...!)
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 10-15-2009, 03:10 PM   #6
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
They know the seasons.
If it was very cold outside and your life
depended on it....you would find a way
in too.
Steel wool every crack you can find, and
then look for more openings to fill!
kennethowens is offline   Reply With Quote
Old 10-15-2009, 04:21 PM   #7
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
hole for TV umbilical wiring
up front, just behind the very first cross member of the frame, in the spare tire area, there is a hole for the DC wiring from the 7/9 pin connector to get into the AS coach. That hole, if not plugged well can be a super highway for critters. Steel wool, is okay, but perhaps aluminum wool (much coarser than steel) that won't rust and ultimately fluff away-I'd bet that hole is open.
wmarsha is offline   Reply With Quote
Old 10-24-2009, 11:23 PM   #8
HankO's Avatar
1997 28' Excella
Eden , Utah
Mouse Problem eliminated
Ok, I think I have finally figured out how to get rid of the mice. Trying to block every opening in a 28 foot Airstream seemed like a daunting task and you never get every opening. On a month long fishing trip at a campground in Idaho, I was discovering mice getting in my trailer on a nightly basis. Five nights in a row I was catching mice in a spring loaded trap and could hear the little buggers moving around the trailer. I finally decided to set up a trap outside and try to get rid of them before they entered the trailer. I found a 5 gallon bucket and drilled a hole large enough to put a 1 inch dowel through the middle of the bucket near the top (right through the center of the bucket). I then put a used up toilet paper tube in the middle of the dowel and coated the sides with peanut butter. I found a piece of pine and built a little ramp for them to go up to the top of the bucket. Filled the bucket 1/2 full of water, put the bucket under the trailer next the the wheels, and waited till morning. First morning I had 5 mice in the bottom, second morning 4, third morning 2, fourth morning none, and no more mice in trailer. I haven't seen another mouse in the outside trap for a couple of nights. One more note, I put a little peanut butter along the ramp to lure them up to the top of the bucket.
Good mouse hunting,
Hank
HankO is offline   Reply With Quote
Old 10-25-2009, 07:57 AM   #9
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
Is there a picture of this ?????
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 10-25-2009, 11:23 AM   #10
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
HankO, this sounds like an interesting solution. I, too, would like pictures. How do you secure the dowel to the center of the bucket and ensure the bucket doesn't leak? How does the dowel stay upright? I am also unsure how the toilet paper tube works. Does it hold tight around the dowel or is it glued in place. Any pics would be greatly appreciated.
At the end of our street, about 2 blocks away, are the university's agricultural program test plots. When they harvest, all the little critters run down to our house. We've had them come into our house through our fireplace. We solved that problem, but our garage has become a playground for them. It's not unusual to catch 30 in September alone. We've found the best traps are the old-style spring-loaded kind...the others often injure them badly, but they stay alive. It's sad for me to see. The new Victor plastic spring loaded ones aren't good. I caught 2 this summer with squished heads, but still alive. I'm a city girl, and I can't kill them, so I let them go in the back alley with their little cone-heads and terrible headaches.
So far, they haven't found their way into our AS, but that is surely only luck. The time is coming. I like the ramp and bucket idea. I need to catch them BEFORE they get into the AS or garage. I'm so sick of the smell of mouse urine in our garage.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 10-25-2009, 11:58 AM   #11
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The dowel goes across near the top of the bucket. It sounds like the toilet paper tube is meant to roll freely around the dowel. This allows the mice to "roll" into the water once they step on it. Kinda like a clumsy lumberjack. The dowel holes in the bucket don't need to be sealed as it's only filled half way.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-25-2009, 03:48 PM   #12
tallytwo1994's Avatar
tallahassee , Florida
The bucket solution comes with variations. I remember seeing one about 30 years ago where a board/ramp was placed against the edge of a 5 gal. bucket that was half filled with water. I think the peanut butter was placed under the edge of the ramp. Once over the edge of the ramp it would tip forward they fell in the water and drowned. This was placed around the outdoor storage area of a restaurant. They also used shallow pans of Pepsi which was suppose to kill them because mice/rats aren't suppose to be able to burp. Guess it was as good as a malfunctioning spring trap.
But the best solution I've heard is to put Bounce sheets throughout the trailer. They don't like the smell and leave. Have to admit I'd stay away too. All dryer sheets smell sweetly sick to me.
Carol
tallytwo1994 is offline   Reply With Quote
Old 10-25-2009, 05:51 PM   #13
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Mouse,mice
See the tread from yesterday on the forums.
http://www.airforums.com/forums/f476...oof-57784.html
Said to use "FRESH-CAB" to keep them out.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 10-25-2009, 08:45 PM   #14
HankO's Avatar
1997 28' Excella
Eden , Utah
Mouse Trap
I put a dowel at the top of the bucket. This can be done two ways, one is drill a hole a little larger than the dowel on both sides of the bucket near the top and feed the dowel through it. The other is to notch out a "U shape" in the top of the bucket and set the dowel in it. The paper roll is set in the center of the dowel and spins free. I put peanut butter on both sides of the paper roll, and when the mice run onto it to feed on the peanut butter they spin into the bucket.
That's it,
Hank
Mice!! Help! dreamer60 General Repair Forum 30 08-07-2009 07:12 PM
Mice not2tacky Plumbing - Systems & Fixtures 4 03-01-2009 05:46 PM
Mice !! silverlassie General Repair Forum 40 04-04-2004 03:07 PM
Mice Problems? apple 1 Our Community 0 01-31-2003 10:17 AM
mice wallybyam Off Topic Forum 2 01-29-2003 12:29 PM
