Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 01-08-2007, 02:34 PM   #1
lexington , Kentucky
Looking to buy 77 Argosy
My wife and I are planning to retire soon and want to travel. We plan to buy a travel trailer and are looking at a 77 Argosy, 26 ft. I have read a lot on this forum and at other places and feel the price is reasonable. It is in fairly good shape overall and all original as far as I can tell. There are, however, several things I know will have to be done. I have several specific questions but don’t know if this “introductory” forum is the appropriate place for those. The owner is asking $3800 and I think we will have to spend between $3500 and $4000 on things I know will have to be done. I would appreciate any opinions regarding the price, etc. or suggestions from those of you with more experience.
Thanks.
gbennett is offline   Reply With Quote
Old 01-08-2007, 03:08 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Thanks.
Welcome to the forums and you will find plenty of good help here. The asking price seems very reasonable but without further info on the things you think need attention it is hard to say. Photos are also very helpful. Don't worry too much about your post being in the wrong spot, the MODS are very good at getting your posting into the right nitch. Let us know what is not working or what concerns ou have and we can all see if we can help!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-08-2007, 03:14 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Gary -- Welcome to the Forums! That seems to be pretty close to other prices I've seen on similar units. That era of just sub-8' wide units are fun and easy to tow. It's a little tough to tell you all of what you will face but I'll bet it's a lot more than replacing window gaskets & roof vent seals.
  • Period furnaces may not be safe but aren't the most expensive to replace either (carbon monoxide). You can check out some basic costs by looking at campingworld.com. The major systems on any RV have stayed about the same modular size/capacity over the decades though the plumb-in points will change somewhat.
  • HW heater? Check it out -- not always easy to do unless the owner has been actively running water thru the system -- look at the tank up front -- if it's dark it may be full of algae.
  • Air conditioner -- find a 30A outlet (campground) and try it out. Never use a 15A-30A adapter to run the A/C; that's hard on the compressor.
  • Fridge -- original? You'll want something like the original 2-way (110V or LP gas) for best options while out camping. This can be one of the more expensive replacement items. It's also difficult to check out -- it can take 1-2 days plugged in before it will really get cool (possibly at the long end of that time if running it on LP). It may work on one and not the other -- we have a lot of folks who have worked on these, though miracles aren't always possible on a 'mostly dead' fridge.
  • Black tank? Has the unit been in use? What was left in the tank the last time it was used... ulp, how many years ago? How about the waste gate & seals on that?
  • Axles -- You may get by bringing it home or doing some local travel, but will definitely need to see if they need replacing before you'd want to take on any long voyages.
  • This is a 30 year old unit -- expect that it may need some floor repairs. Mine did under the water tank in front (window leak), under the battery compartment (seal under tray bad), and at the rear bumper -- very common but hard to see with rubrail trim low on rear platform, but old caulk back there has likely aged. If it smells musty inside it more than likely has some floor rot issues somewhere; this isn't a deal killer if you are up to pulling everything apart but can stretch you out to 1-2 years before you have most of the systems put back together.
Until you really do a good autopsy on a purchase it is not possible to guess whether $4000 on repairs is realistic. It may be close if you're good at DIY -- but will be very far off if you'll need new axles and either an A/C or fridge. If totally fixed up I've seen asking prices close to $10,000, so the purchase price + repairs may exceed that. It just depends on your values, how you want to travel, etc. The other side of the picture is that you'll have a really cool Argosy when you're done -- and just about none of the other RVs (SOBs - 'square old box' or 'some other brand') built back in that period will be competing for oohs and aahs when you roll into a campground!
5 meter Langford Nahanni
Old 01-08-2007, 04:06 PM   #4
Retired.
. , At Large
The price doesn't sound bad, but...
Air Conditioner--$800+ installation
Axles-- $1800+ installation
Fridge-- $1200+installation
Paint(outside)-$2300
______
=$6100 + installation of the components.
Then, if the water heater has to be replaced--$300 + installation
The furnace --$400 + installation
These are the biggest ticket items, check them thoroughly, and plan on replacing most of them within 3 camping seasons.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 40 02-13-2022 05:20 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
