Old 05-29-2017, 09:43 PM   #1
snappykelly
snappykelly's Avatar
1986 25' Sovereign
North Bend , Oregon
Looking for the right Airstream
Hi. ROOKIE. I might as well just own that...
I'm looking at a Sovereign, VIN # J1266564. The plate says "LAND YACHT" above the number. It is supposed to be 1964, with title. $8500, it needs work- plus oven not working, owner removed support for table near couch, no awnings. Questions: 1) Price 2) I can tow up to 5000 with my current vehicle 3) help.
Kelly Barnett:
snappykelly is offline   Reply With Quote
Old 05-29-2017, 11:33 PM   #2
Coloradobus's Avatar
Do you have a photo of whole trailer.
JIM n CHRIS
"62 ATW Overlander, '51 Flying Cloud
'67 GT, '90 Squarestream 29ft, 06 Bambi, Bigfoot slide in/GMC Denali K2500, Marathon Coach, Class A.
Coloradobus is offline   Reply With Quote
Old 05-29-2017, 11:38 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Hi there Kelly...welcome to AirForums!
The VIN # indicates that what you are looking at is a:
J = Ohio built
I (1) = International Trim Level
26 = 26' Overlander
6 = 1966 (not a 1964)
5 = double bed layout
64 = sequential build number
Pictures of the same year & model can be found here: Airstream Archives - 1966 Overlander as well as the VIN # coding.
This page, Price vs Condition will help you ascertain whether the asking price is in-line with the condition - without pictures and based on your basic description, it seems high.
No, it should not be towed with a vehicle with a tow rating of only 5000 lbs. A 26' Overlander has a "dry weight" of 3850 lbs and that means without any options, water, gas tanks or anything in it. Once loaded for a trip you would most likely be tipping the scales close to 4500-5000 lbs. Generally speaking, a tow vehicle rated for 5000 lbs is most likely a bit exaggerated - it's "rating" is taken at sea level, when new and perfectly tuned. Also a TV rated at 5000 lbs probably has too short of a wheelbase to safely tow that big of a trailer....sorry! You could probably move the trailer - but it will kill your vehicle by towing over any distance or with less than perfect conditions....and make for a miserable, not to mention un-safe experience.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-30-2017, 12:47 AM   #4
I concur with Shari.
http://vintageairstream.com/photo-ar...overlander-26/
JIM n CHRIS
Old 05-31-2017, 01:05 AM   #5
snappykelly
1986 25' Sovereign
North Bend , Oregon
Thanks SO MUCH! I joined the Airstream Forums in 2002, and periodically login to learn. This is exactly the info I needed. I'd prefer to keep the vehicle I have, so I think I need to look for a lighter AS when fully loaded.
Kelly Barnett:
Right sealants on the right sections BoldAdventure Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2014 12:09 PM
Looking for the right Airstream Tumajin Member Introductions 2 10-18-2010 01:32 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 08:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 09:50 PM
looking for the right airstream mark a. Member Introductions 11 09-09-2007 08:25 PM
