Old 11-22-2007, 10:44 AM   #1
Arden , North Carolina
Question looking for Airstream, towing issues
I am looking for an Airstream-
-needs sleeps 4 comfortably- 6 in a pinch-no sleeping on a table top
want a used model but not needing repairs
want a model tha is easy to back and tow
ease of setup and break down really ,really important
cost is an issue with a target of $26,000 or less
The tow vehicle I am considering is:
Avalanche 2008
Tundra 2008
possibly a Honda Ridgline( will it pull what I want for comfort?)
comments or suggestions would be appreciated
swifty6 is offline   Reply With Quote
Old 11-22-2007, 10:55 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Hi swifty6,
I used to have a 25' Safari 6-sleeper that would work, but you do need to drop the dinette table to make a bed to get those last two people in. It has a double corner bed, a goucho(sofa) and dinette that each make into a bed.
The Avalanche and Tundra would be able to tow it, not so sure about the Honda. Probably not.
Fyrzowt is offline   Reply With Quote
Old 11-22-2007, 11:38 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Comprimises
My Classic 31 Will comfortably sleep four, six in a pinch. Thats two in the master bed, One on the dinette(two if necessary) and one (two if necessary) on the couch.
Almost all will need some repairs. They get used or not used they still break. Some things break from lack of use others from use.
want a model that is easy to back and tow
The larger ones are easier to back. The smallers one are easier to tow.
Same across the board.
Your will be looking at a older trailer. Say 1990s. That will need some repairs.
Avalanche 2008
Tundra 2008
Thse will depend on your choice of trailer. Pick that first then the truck.
Use the 80% rule. If the trailer weighs 5000 lbs fully loaded pick a truck that is rated for at least 6000 lbs.
Michelle TAC MT-0
Sarah, Snowball
Old 11-22-2007, 02:42 PM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
The Ridge max tow rating is 5000'. I don't have a problem as our 22' SS total weight is just over 4000# loaded and I don't need a WD hitch or sway control. Sounds like your gonna need something around 28'-31' and maybe the Avalanche.
Ahab is offline   Reply With Quote
Old 05-26-2010, 09:33 AM   #5
Newport Beach , California
Is that the 83% rule you're talking about there ? If you're allowed to break the rule, how much cushion are you allowed ? 3%, 4%, 5% ?
Should we just call it the 85% rule ? Just wondering...
RognChris is offline   Reply With Quote
Old 06-01-2010, 03:27 PM   #6
1987 31' Excella
Lake City , Florida
i am towing with 2007 tunda w/5.7 6speed trans & toe pag. AS 31' w/ sway controls.wt of AS is 8300. pulls great. i found the AS on craigs list it had been up graded & now i am compounding to a bright polish, not bad for 11G.
robertbeavers is offline   Reply With Quote
Old 06-05-2010, 05:10 AM   #7
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
I'm pulling my '77 Soveriegn with a '99 Suburban, slightly modified engine -- but very stable pulling, slow up hills but I'm not in a hurry. My rig weighs on the order of 6800# fully loaded. I've upgrade the torflex axles from the stock 3200# to the 3600# units - well worth the investment, IMHO.
Good luck in finding what meets your needs...
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Parents seriously injured while towing Airstream LittleRadio On The Road... 89 06-28-2007 06:55 PM
Towing My Airstream Pinkerton 1970-79 Tradewind 10 04-27-2007 06:08 AM
Towing behind Airstream? andyfuson Towing, Tow Vehicles & Hitches 15 04-10-2007 10:58 AM
towing tandem with an airstream wvabeer Towing, Tow Vehicles & Hitches 12 09-27-2005 12:01 PM
Safari 25' Model A towing issues rtierney 2003 Safari 11 07-02-2003 10:15 AM
